Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓In this Replacement Guide, you will find the steps and process to replace the Outer Shell of the JBL Go 4.
The shell or case protects the device from accidents such as drops, slips, or slides, helping to keep the internal structures intact. The shell also provides a level of waterproofing for the device, while it's not the main waterproofing, it helps to keep things out.
If the shell becomes damaged, the quality of the speakers output can be hurt as well as the visual aesthetics.
Note: The device used in this guide is a non-genuine model, so the internal components may look different from those in your authentic device. However, the replacement procedure remains roughly the same and should still apply to your device.
Remove the speaker's grille by inserting the tip of an opening tool into the top corner, opposite the strap.
Slide the tool along the edge of the housing until it pops off. Place it to the side.
At this point, you should switch over to the JBL Go 4 Battery Replacement, and follow the steps to remove the battery
Once the battery is removed, use a strong adhesive to adhere it to the new shell and follow the steps in reverse.
