JBL Go 3 Motherboard Replacement
    1. JBL Go 3 Motherboard Replacement, Grille: step 1, image 1 of 3 JBL Go 3 Motherboard Replacement, Grille: step 1, image 2 of 3 JBL Go 3 Motherboard Replacement, Grille: step 1, image 3 of 3
      • Using an iFixit Opening Pick or a Jimmy, pry along the seam between the rubber outer layer and the hard shell.
      • Work your way around the edges until the shell loosens and can be fully removed.
      Ask FixBot
    2. JBL Go 3 Motherboard Replacement: step 2, image 1 of 3 JBL Go 3 Motherboard Replacement: step 2, image 2 of 3 JBL Go 3 Motherboard Replacement: step 2, image 3 of 3
      • Align the new shell with the speaker’s body, making sure all edges are properly positioned.
      • Press firmly around the edges until the shell snaps securely into place.
      Ask FixBot
    1. JBL Go 3 Motherboard Replacement, Motherboard: step 3, image 1 of 3 JBL Go 3 Motherboard Replacement, Motherboard: step 3, image 2 of 3 JBL Go 3 Motherboard Replacement, Motherboard: step 3, image 3 of 3
      • Locate the internal screws underneath the outer shell.
      • Unscrew and remove the screws using a precision screwdriver.
      • Carefully lift the casing to expose the motherboard.
      Ask FixBot
    2. JBL Go 3 Motherboard Replacement: step 4, image 1 of 1
      • Remove the screws securing the motherboard to the internal casing.
      • Gently disconnect the battery from the motherboard.
      • Locate the wires that lead from the speaker to the motherboard.
      • Carefully pull the red connector from the motherboard and avoid pulling on wires.
      • Carefully lift and remove the motherboard.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Kasey Oliver
507 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 48
Past 30 Days: 157
All Time: 802
