Up to 20% off select tools
JBL Go 3 Battery Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
25
Past 7 Days:
93
Past 30 Days:
434
All Time:
2,823
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 10 - 25 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
If your JBL Go 3 battery stops holding a charge over time, you may need to replace it. It's a common issue with many speakers. Follow the guide below to replace the battery yourself.
    1. JBL Go 3 Battery Replacement, Battery: step 1, image 1 of 2 JBL Go 3 Battery Replacement, Battery: step 1, image 2 of 2
      • Use a Jimmy or opening tool to gently lift one corner of the fabric mesh, then carefully remove the entire fabric and shell.
      • Insert the Jimmy along the seam and gently pry open the housing.
      • Work your way around the speaker, unclipping the internal latches as you go.
      Ask FixBot
    2. JBL Go 3 Battery Replacement: step 2, image 1 of 3 JBL Go 3 Battery Replacement: step 2, image 2 of 3 JBL Go 3 Battery Replacement: step 2, image 3 of 3
      • Use a screwdriver to remove the screws securing the motherboard to the device.
      • Locate the battery, it’s usually wrapped in black or silver and connected to the mainboard by a small cable.
      • Carefully disconnect the battery connector from the circuit board.
      • Remove the old battery, replace it with the new one and reconnect the cable securely.
      • Close the housing, screw everything back in place, and reattach the fabric mesh.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Kasey Oliver
507 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 25
Past 7 Days: 93
Past 30 Days: 434
All Time: 2,823
