JBL Flip 6 Woofer Replacement
  1. JBL Flip 6 Woofer Replacement, Case: step 1, image 1 of 2 JBL Flip 6 Woofer Replacement, Case: step 1, image 2 of 2
    • Using the iFixit opening tool, pry up on the button side of the slot on the case until the clips release.
    Ask FixBot
  2. JBL Flip 6 Woofer Replacement: step 2, image 1 of 2 JBL Flip 6 Woofer Replacement: step 2, image 2 of 2
    • Now that the gap is larger, using the same tool, pry up on the other side until the clips release.
    Ask FixBot
  3. JBL Flip 6 Woofer Replacement: step 3, image 1 of 3 JBL Flip 6 Woofer Replacement: step 3, image 2 of 3 JBL Flip 6 Woofer Replacement: step 3, image 3 of 3
    • With all clips released, slide the case off longways.
    • You may need to spread it a bit with your hands so that the clips do not become caught on the end pieces.
    Ask FixBot
  4. JBL Flip 6 Woofer Replacement, Woofer: step 4, image 1 of 3 JBL Flip 6 Woofer Replacement, Woofer: step 4, image 2 of 3 JBL Flip 6 Woofer Replacement, Woofer: step 4, image 3 of 3
    • Remove the four 9.5 mm Philips #1 screws securing the woofer to the device.
    Ask FixBot
  5. JBL Flip 6 Woofer Replacement: step 5, image 1 of 3 JBL Flip 6 Woofer Replacement: step 5, image 2 of 3 JBL Flip 6 Woofer Replacement: step 5, image 3 of 3
    • Carefully disconnect the white connector linking the woofer and the motherboard.
    • If there is a lot of resistance when removing the plug, there could be a clip holding it in place. Check for any sort of fasteners before using much strength as you could damage the motherboard.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
1 Guide Comment
Hola!!!..Dónde lo puedo conseguir acá en Argentina?
eltrapitoeag01 - Reply Share
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 188
All Time: 2,701
