JBL Flip 5 Motherboard Replacement
  1. JBL Flip 5 Motherboard Replacement, Outer Case: step 1, image 1 of 2 JBL Flip 5 Motherboard Replacement, Outer Case: step 1, image 2 of 2
    • Insert the flat edge of the metal spudger underneath the corner of the outer case.
    • Use the spudger to pry open the plastic clips that secure the outer case.
    Ask FixBot
  2. JBL Flip 5 Motherboard Replacement: step 2, image 1 of 1
    • Once all the clips are released, you will be able to pull up that edge of the case.
    Ask FixBot
  3. JBL Flip 5 Motherboard Replacement: step 3, image 1 of 1
    • Once one side is released, complete the previous two steps with the other side.
    • This side contains the buttons, so be careful so as to not damage them while prying the case off.
    Ask FixBot
  4. JBL Flip 5 Motherboard Replacement: step 4, image 1 of 2 JBL Flip 5 Motherboard Replacement: step 4, image 2 of 2
    • Once all the clips are removed, you can gently remove the outer case.
    • The case is now fully removed. Now a new case will be attached by putting the case into position and pushing on the clips to reattach them.
    Ask FixBot
  5. JBL Flip 5 Motherboard Replacement, Speaker: step 5, image 1 of 1
    • Begin by unscrewing the four 9.6 mm-long screws with the Philips #00 screwdriver.
    • Make sure to be careful with the gasket under the edges!
    Ask FixBot
  6. JBL Flip 5 Motherboard Replacement: step 6, image 1 of 1
    • Once screws are fully out make sure to carefully pull out so the wires connected don't get damaged.
    Ask FixBot
  7. JBL Flip 5 Motherboard Replacement: step 7, image 1 of 1
    • Once you carefully lift up the speaker, gently disconnect the wire that connects the speaker to the motherboard.
    Ask FixBot
  8. JBL Flip 5 Motherboard Replacement: step 8, image 1 of 1
    • Once connection has been disconnected you can lift the speaker completely out.
    Ask FixBot
  9. JBL Flip 5 Motherboard Replacement, Buttons: step 9, image 1 of 3 JBL Flip 5 Motherboard Replacement, Buttons: step 9, image 2 of 3 JBL Flip 5 Motherboard Replacement, Buttons: step 9, image 3 of 3
    • The next part needed to remove covers each side and the power and bluetooth buttons in a middle strip along the speaker.
    • The first picture is for reference. That is the part that will be removed.
    • Begin (as shown in the second picture) by unscrewing the two screws (17mm each) with the Philips #00 screwdriver.
    • Then flip the device around and unscrew the other two screws (17 mm each) on the other side just the same.
    • In these pictures the speaker is still in the device. It is best to have already removed it in the Speaker Replacement Guide.
    Ask FixBot
  10. JBL Flip 5 Motherboard Replacement: step 10, image 1 of 2 JBL Flip 5 Motherboard Replacement: step 10, image 2 of 2
    • Once all the screws are removed, pull the passive radiator bracket on either end off.
    • Set the passive radiator bracket to the side. It is not needed for the buttons replacement.
    Ask FixBot
  11. JBL Flip 5 Motherboard Replacement: step 11, image 1 of 3 JBL Flip 5 Motherboard Replacement: step 11, image 2 of 3 JBL Flip 5 Motherboard Replacement: step 11, image 3 of 3
    • Next you must remove the passive radiator.
    • To do so use the metal spudger to undo the clips holding it down.
    • Once the clips on both sides are removed, you can pull the left and right passive radiators off the device.
    • Both can be set aside. They are not needed for the buttons replacement.
    Ask FixBot
  12. JBL Flip 5 Motherboard Replacement: step 12, image 1 of 2 JBL Flip 5 Motherboard Replacement: step 12, image 2 of 2
    Tool used on this step:
    Buy
    • Once the speaker is removed, you must go in through the hole where the speaker was for this step.
    • There you can use tweezers or your fingers to unhook the connection of the buttons board to the rest of the device.
    Ask FixBot
  13. JBL Flip 5 Motherboard Replacement: step 13, image 1 of 2 JBL Flip 5 Motherboard Replacement: step 13, image 2 of 2
    • Peel the rubber cover off using a metal spudger. It may be very sticky, so you may need to pull hard.
    • Then peel the cover off using your fingers.
    Ask FixBot
  14. JBL Flip 5 Motherboard Replacement: step 14, image 1 of 2 JBL Flip 5 Motherboard Replacement: step 14, image 2 of 2
    • Again use the spudger to pull the buttons board off.
    • It is glued down, so you must be very assertive using the spudger.
    Ask FixBot
  15. JBL Flip 5 Motherboard Replacement: step 15, image 1 of 2 JBL Flip 5 Motherboard Replacement: step 15, image 2 of 2
    • In these photos, the buttons board is still on.
    • If only certain buttons are not working it may be appropriate to only replace the buttons board with play/pause and volume up/down. If you are having trouble with the power and bluetooth buttons as well, this step will allow you to replace those.
    • Use the metal spudger to again pull the board containing the power and bluetooth buttons off from the device. It is located next to the strap.
    • It's glued on, use necessary force.
    Ask FixBot
  16. JBL Flip 5 Motherboard Replacement, Motherboard: step 16, image 1 of 1
    • Remove the black tape attached to the inside of the speaker.
    • The adhesive used is strong and may need more force if there is no progress.
    Ask FixBot
  17. JBL Flip 5 Motherboard Replacement: step 17, image 1 of 1
    • Remove the wiring attached to the motherboard and leave it facing away when pulling the motherboard out.
    • This part is attached on and is very tight. Do not pull from the wire and pull from the plastic head to prevent damage.
    Ask FixBot
  18. JBL Flip 5 Motherboard Replacement: step 18, image 1 of 3 JBL Flip 5 Motherboard Replacement: step 18, image 2 of 3 JBL Flip 5 Motherboard Replacement: step 18, image 3 of 3
    • First, slide the battery fully out. You may need to tilt it up slightly to remove it fully and then gently start to pull the motherboard out the same way. Again, you need to gently tilt it up halfway to fully remove it.
    Ask FixBot
  19. JBL Flip 5 Motherboard Replacement: step 19, image 1 of 1
    • Once you have the motherboard removed, repair the motherboard before putting it back in or replace it with a new motherboard.
    Ask FixBot
NoahD
136 Reputation
1 Guide authored
UMass Dartmouth, Team 3-5, Konn Fall 2023 Member of UMass Dartmouth, Team 3-5, Konn Fall 2023
UMASSD-KONN-F23S3G5
4 Members
7 Guides authored
2 Guide Comments
There seem to be different versions of the Flip 5. My one (I think that it called the GG version) had two ribbon cables attached to the edge shown in step 18 and the rest of the motherboard was different. The problem with my one was that one conductor in the 6 conductor ribbon had been damaged from pressure on something internally which had resulted in a non functioning vol+ button.
geoffrey - Reply Share
Same here...
Also the speaker has 3 wires which each need to be pulled off the speaker. Cables are soldered to the MB
Step 9 doesn't have screws on mine
Jan-Willem - Reply Share
Past 24 Hours: 8
Past 7 Days: 24
Past 30 Days: 147
All Time: 3,126
