JBL Flip 5 Charging Port Replacement
  1. JBL Flip 5 Charging Port Replacement, Outer Case: step 1, image 1 of 2 JBL Flip 5 Charging Port Replacement, Outer Case: step 1, image 2 of 2
    • Insert the flat edge of the metal spudger underneath the corner of the outer case.
    • Use the spudger to pry open the plastic clips that secure the outer case.
    Ask FixBot
  2. JBL Flip 5 Charging Port Replacement: step 2, image 1 of 1
    • Once all the clips are released, you will be able to pull up that edge of the case.
    Ask FixBot
  3. JBL Flip 5 Charging Port Replacement: step 3, image 1 of 1
    • Once one side is released, complete the previous two steps with the other side.
    • This side contains the buttons, so be careful so as to not damage them while prying the case off.
    Ask FixBot
  4. JBL Flip 5 Charging Port Replacement: step 4, image 1 of 2 JBL Flip 5 Charging Port Replacement: step 4, image 2 of 2
    • Once all the clips are removed, you can gently remove the outer case.
    • The case is now fully removed. Now a new case will be attached by putting the case into position and pushing on the clips to reattach them.
    Ask FixBot
  5. JBL Flip 5 Charging Port Replacement, Charging Port: step 5, image 1 of 3 JBL Flip 5 Charging Port Replacement, Charging Port: step 5, image 2 of 3 JBL Flip 5 Charging Port Replacement, Charging Port: step 5, image 3 of 3
    • The first picture is for reference. That is the part that will be removed.
    • Use a Phillips screwdriver to remove the four 17mm-long screws securing the passive radiator bracket.
    Ask FixBot
  6. JBL Flip 5 Charging Port Replacement: step 6, image 1 of 3 JBL Flip 5 Charging Port Replacement: step 6, image 2 of 3 JBL Flip 5 Charging Port Replacement: step 6, image 3 of 3
    • Once the screws are removed, use the metal spudger to remove the passive radiator bracket.
    • Set the radiator bracket aside.
    Ask FixBot
  7. JBL Flip 5 Charging Port Replacement: step 7, image 1 of 3 JBL Flip 5 Charging Port Replacement: step 7, image 2 of 3 JBL Flip 5 Charging Port Replacement: step 7, image 3 of 3
    • Now you must remove the passive radiator.
    • Use the metal spudger to pry upwards to remove the plastic clips holding the passive radiator down.
    • Once the clips are removed, you can pull both of the passive radiators off
    Ask FixBot
  8. JBL Flip 5 Charging Port Replacement: step 8, image 1 of 2 JBL Flip 5 Charging Port Replacement: step 8, image 2 of 2
    • Focus on the side of the speaker where the charging port is located and inspect where the passive radiator was before it was removed.
    • Use your hands to unplug the charging cable that connects the charging port to the motherboard.
    • You can use a plastic spudger to assist if necessary.
    Ask FixBot
  9. JBL Flip 5 Charging Port Replacement: step 9, image 1 of 2 JBL Flip 5 Charging Port Replacement: step 9, image 2 of 2
    • Unfasten the four 6 mm-long screws on the component that sits over the charging port.
    • Remove this piece with your hands.
    Ask FixBot
  10. JBL Flip 5 Charging Port Replacement: step 10, image 1 of 3 JBL Flip 5 Charging Port Replacement: step 10, image 2 of 3 JBL Flip 5 Charging Port Replacement: step 10, image 3 of 3
    • There will be two tape like plastic pieces that hold the charging port's circuit in place.
    • Pull these pieces off and you will be able to pull the charging port and its circuit out.
    Ask FixBot
Kevin Barbosa
154 Reputation
1 Guide authored
UMass Dartmouth, Team 3-5, Konn Fall 2023 Member of UMass Dartmouth, Team 3-5, Konn Fall 2023
UMASSD-KONN-F23S3G5
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 145
All Time: 3,190
