Up to 20% off select tools
JBL Flip 4 Shell Replacement
Views: 20K
View statistics:
Past 24 Hours:
16
Past 7 Days:
74
Past 30 Days:
399
All Time:
19,881
Comments: 23
20 comments on steps, 3 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide details how to remove the outer shell and the rubber spine on the speaker. This guide also marks the first steps to access the JBL Flip 4's battery, speakers, circuit boards, etc.
    1. JBL Flip 4 Shell Replacement, Shell: step 1, image 1 of 3 JBL Flip 4 Shell Replacement, Shell: step 1, image 2 of 3 JBL Flip 4 Shell Replacement, Shell: step 1, image 3 of 3
      • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
      • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
      • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
      • Watch out not to damage the clips on the buttons' side, pry open with caution.
      • Pull the cover off with your thumbs.
      Ask FixBot
    2. JBL Flip 4 Shell Replacement: step 2, image 1 of 3 JBL Flip 4 Shell Replacement: step 2, image 2 of 3 JBL Flip 4 Shell Replacement: step 2, image 3 of 3
      • Remove four 13 mm JIS #0 screws attaching the rubber spine to the speaker, located on both sides of the inside of the speaker.
      • Use the plastic opening tool to release the clips holding the central part of the rubber spine.
      • Pry away one end of the rubber spine with your thumbs and it should come off.
      • Prying off the spine may take some persuading.
      • The speakers are strong magnets. Keep it away from other sensitive electronics.
      Ask FixBot
12 other people completed this guide.
Author
with
Philip Pang
1,503 Reputation
4 Guides authored
Cal Poly, Team S4-G3, White Fall 2018 Member of Cal Poly, Team S4-G3, White Fall 2018
CPSU-WHITE-F18S4G3
4 Members
60 Guides authored
3 Guide Comments
教程不难, 难的是哪里可以买到配件。
Toki - Reply Share
Buenas tarde busco remplazo de carcasa frontal del jbl flit 4
william marin lopez - Reply Share
@williammar67632 si encontro la pieza disculpe
Gerardo Parra - Reply Share
Past 24 Hours: 16
Past 7 Days: 74
Past 30 Days: 399
All Time: 19,881
