JBL Flip 3 Front Active Driver Replacement
    1. JBL Flip 3 Front Active Driver Replacement, Front Active Driver: step 1, image 1 of 1
      • Remove plastic outer housing using hands or a standard spudger.
      Ask FixBot
    2. JBL Flip 3 Front Active Driver Replacement: step 2, image 1 of 1
      • Using your hands, carefully remove outer housing and frame to expose the internal workings of the speaker.
      Ask FixBot
    3. JBL Flip 3 Front Active Driver Replacement: step 3, image 1 of 1
      • Remove the 8.9mm Phillips #00 screws on each corner of the driver to be replaced. There are four screws per driver. Be sure to set the screws somewhere safe to ensure they aren’t lost.
      Ask FixBot
    4. JBL Flip 3 Front Active Driver Replacement: step 4, image 1 of 1
      • Remove the 3-pin connector from motherboard.
      Ask FixBot
17 other people completed this guide.
College Student
3,670 Reputation
4 Guides authored
USF Tampa, Team S1-G2, Leahy Spring 2017 Member of USF Tampa, Team S1-G2, Leahy Spring 2017
USFT-LEAHY-S17S1G2
5 Members
60 Guides authored
7 Guide Comments
where did you source the drivers from?
Rashid Saad Siddiqui - Reply Share
hi my flip 3 1 speaker is have give the problem thats not give the clear voice , so i want to change the parts can u help me i am where to buy this parts
manu - Reply Share
I too want to know where you can buy new drivers. Can't find them online so far...
Johannes - Reply Share
i need help getting the front speakers only where would i get them???
brian ortiz - Reply Share
Sir
my flip 3 Both speaker is have give the problem thats not give the clear voice , so i want to change the parts can u help me i am where to buy this parts
Anil Kumar Hembrom - Reply Share
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 64
All Time: 21,318
