JBL Flip 3 Battery Replacement
    1. JBL Flip 3 Battery Replacement, Battery: step 1, image 1 of 1
      • Remove plastic outer housing using hands or a standard spudger.
      • Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
      Ask FixBot
    2. JBL Flip 3 Battery Replacement: step 2, image 1 of 1
      • Loosen the two screws on each side and then carefully remove the outer frame to expose the inner components of the speaker.
      • Depending on your model, you may need to remove more screws along the sides or the spine.
      Ask FixBot
    3. JBL Flip 3 Battery Replacement: step 3, image 1 of 1
      • Remove the 7 8.9mm Phillips #00 screws fastening the two side passive drivers. Then remove the side passive drivers themselves. Be sure to set them somewhere safe to ensure they aren’t lost.
      Ask FixBot
    4. JBL Flip 3 Battery Replacement: step 4, image 1 of 1
      • Remove silicone button covers by peeling back the silicone covering. This will expose the circuit board. Disconnect the ribbon cable. Carefully pry out the circuit board and set aside. Use a heat gun to remove all adhesive so that the ribbon cable can freely slide out of the slot in a later step.
      Ask FixBot
    5. JBL Flip 3 Battery Replacement: step 5, image 1 of 1
      • Carefully remove the 5 pin connector from motherboard using your hands
      Ask FixBot
    6. JBL Flip 3 Battery Replacement: step 6, image 1 of 2 JBL Flip 3 Battery Replacement: step 6, image 2 of 2
      • Unscrew the 2 8.9mm Phillips #00 screws holding the plastic battery cover. Carefully set them in a different safe spot to ensure that they are both not lost and not confused with the screws from step 2.
      • Remove the clear plastic battery cover.
      Ask FixBot
    7. JBL Flip 3 Battery Replacement: step 7, image 1 of 2 JBL Flip 3 Battery Replacement: step 7, image 2 of 2
      • Gently heat adhesive located at tip of powerchip to melt the plastic fastening the battery to the housing. Be careful not to melt the plastic housing during heating.
      • Heat gun safety: http://www.powertoolinstitute.com/pti_pd...
      Ask FixBot
    8. JBL Flip 3 Battery Replacement: step 8, image 1 of 1
      • Remove the ribbon holding the battery. When the ribbon is gently pulled until fully removed from the inner housing, the battery will be unfastened and removable.
      Ask FixBot
50 other people completed this guide.
College Student
3,670 Reputation
4 Guides authored
USF Tampa, Team S1-G2, Leahy Spring 2017 Member of USF Tampa, Team S1-G2, Leahy Spring 2017
USFT-LEAHY-S17S1G2
5 Members
60 Guides authored
32 Guide Comments
where can I get replacement battery for Flip 3?
Gaurav Gupta - Reply Share
You can get a replacement battery for the JBL flip 3 on AliExpress
Ezriel Greenman - Reply Share
It is couple diffrent version of JBL Flip 3 speaker .
Dalibor Miljevic - Reply Share
Yes, apparently the Flip 3 Stealth Edition looks slightly different. The procedure however is about the same, except screws are not covered by silicone covering.
johnnyheesterbeek - Reply Share
my battery also went to !&&*!! anyone manage to get a replacement?? couldn't find one!
Oscar Motta - Reply Share
Past 24 Hours: 10
Past 7 Days: 149
Past 30 Days: 547
All Time: 118,340
