Up to 20% off select tools
JBL Flip 2 Battery Replacement
Views: 39K
View statistics:
Past 24 Hours:
14
Past 7 Days:
76
Past 30 Days:
334
All Time:
39,422
Comments: 30
17 comments on steps, 13 guide comments.
Go to guide comments
Completed: 22
22 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 25 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
This guide will walk you through from taking apart the device, disconnecting all the cables inside and taking apart the battery for replacement.
There are two versions of the battery in this device; one with three wires and one with five wires. The best way to tell which type of battery you need is to disassemble your device before ordering a replacement battery.
    1. JBL Flip 2 Battery Replacement, JBL Flip 2 Outer Case Disassembly: step 1, image 1 of 2 JBL Flip 2 Battery Replacement, JBL Flip 2 Outer Case Disassembly: step 1, image 2 of 2
      • Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases.
      • Be very careful when removing the NFC rubber cap. There is a chip that is glued to the inside of the rubber cap. So, peel the rubber cap off slowly and remove the chip on the inside while peeling the rubber cap off.
      Ask FixBot
    2. JBL Flip 2 Battery Replacement: step 2, image 1 of 2 JBL Flip 2 Battery Replacement: step 2, image 2 of 2
      • Remove the eight 7.0 mm Phillips #1 screws on both sides of the JBL Flip 2.
      Ask FixBot
    3. JBL Flip 2 Battery Replacement: step 3, image 1 of 3 JBL Flip 2 Battery Replacement: step 3, image 2 of 3 JBL Flip 2 Battery Replacement: step 3, image 3 of 3
      • The NFC chip is glued onto the side of the device. Use the black spudger to separate the mic from the surface.
      • Be careful not to sever the wire connecting the nfc chip to the inside of the device.
      • Gently slide the NFC chip into the device through the slot that the wire comes from.
      Ask FixBot
    4. JBL Flip 2 Battery Replacement: step 4, image 1 of 2 JBL Flip 2 Battery Replacement: step 4, image 2 of 2
      • Peel the black rubber piece from one end to the other.
      Ask FixBot
    5. JBL Flip 2 Battery Replacement: step 5, image 1 of 3 JBL Flip 2 Battery Replacement: step 5, image 2 of 3 JBL Flip 2 Battery Replacement: step 5, image 3 of 3
      • Remove the two 7.0 mm Phillips #1 screws.
      • Carefully detach the silver plastic cover by pulling both ends off.
      • Pull both ends at the same time with the same amount of force to prevent the cover from breaking.
      • Separate the silver plastic piece by pulling it off from the middle.
      Ask FixBot
    6. JBL Flip 2 Battery Replacement: step 6, image 1 of 3 JBL Flip 2 Battery Replacement: step 6, image 2 of 3 JBL Flip 2 Battery Replacement: step 6, image 3 of 3
      • Using a flat-head screwdriver or spudger, pry out the 8 metal nibs on the back side of the speaker.
      • Repeat the same process for the 4 remaining metal nibs (two on each end).
      Ask FixBot
    7. JBL Flip 2 Battery Replacement: step 7, image 1 of 2 JBL Flip 2 Battery Replacement: step 7, image 2 of 2
      • Expand the metal casing and carefully slide it off the speaker.
      Ask FixBot
    8. JBL Flip 2 Battery Replacement: step 8, image 1 of 2 JBL Flip 2 Battery Replacement: step 8, image 2 of 2
      • Using the driver adapter, first insert the #4 socket into the driver; followed by the #1 Philip's head bit in order to reach the three 13.0 mm screws.
      Ask FixBot
    9. JBL Flip 2 Battery Replacement: step 9, image 1 of 3 JBL Flip 2 Battery Replacement: step 9, image 2 of 3 JBL Flip 2 Battery Replacement: step 9, image 3 of 3
      • Using the classic spudger, get underneath the black tape strips found on both side of the device.
      • After lifting a portion of the tape off of the device, gently peel the tape off of the device, making sure to keep it intact.
      • There is another piece of tape on the side of the device with the control buttons. Lift the tape with the classic spudger and then peel the rest of the tape off.
      Ask FixBot
    10. JBL Flip 2 Battery Replacement: step 10, image 1 of 3 JBL Flip 2 Battery Replacement: step 10, image 2 of 3 JBL Flip 2 Battery Replacement: step 10, image 3 of 3
      • Wedge a spudger between the two halves where the tape was to pry the device open.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      Ask FixBot
    11. JBL Flip 2 Battery Replacement: step 11, image 1 of 2 JBL Flip 2 Battery Replacement: step 11, image 2 of 2
      • Use the black spudger to disconnect the speaker cord from it's socket.
      Ask FixBot
    12. JBL Flip 2 Battery Replacement: step 12, image 1 of 2 JBL Flip 2 Battery Replacement: step 12, image 2 of 2
      • Use the black spudger to disconnect the auxiliary wire from its socket.
      Ask FixBot
    13. JBL Flip 2 Battery Replacement: step 13, image 1 of 1
      • Carefully remove the cable connecting the control chip to the motherboard.
      Ask FixBot
    14. JBL Flip 2 Battery Replacement: step 14, image 1 of 2 JBL Flip 2 Battery Replacement: step 14, image 2 of 2
      • Using the black spudger, carefully remove the cord connecting the battery to the motherboard.
      Ask FixBot
    15. JBL Flip 2 Battery Replacement: step 15, image 1 of 1
      • Carefully remove the cable connecting the nfc chip to the motherboard.
      Ask FixBot
    1. JBL Flip 2 Battery Replacement, Battery: step 16, image 1 of 2 JBL Flip 2 Battery Replacement, Battery: step 16, image 2 of 2
      • Remove the one 7.0 mm Phillips #1 screw attaching the motherboard to the casing.
      • Lift the motherboard out of the case to reveal the battery.
      Ask FixBot
    2. JBL Flip 2 Battery Replacement: step 17, image 1 of 2 JBL Flip 2 Battery Replacement: step 17, image 2 of 2
      • Remove the cord that connects the ports board to the motherboard.
      • Put the motherboard to the side.
      Ask FixBot
    3. JBL Flip 2 Battery Replacement: step 18, image 1 of 2 JBL Flip 2 Battery Replacement: step 18, image 2 of 2
      • Using the black spudger, loosen the brace holding in the battery.
      • To remove the brace, turn it 90 degrees clockwise and lift it up from its socket.
      Ask FixBot
    4. JBL Flip 2 Battery Replacement: step 19, image 1 of 2 JBL Flip 2 Battery Replacement: step 19, image 2 of 2
      • Using the black spudger, loosen the battery and remove.
      Ask FixBot
22 other people completed this guide.
Author
with
Jonathan Wear
1,300 Reputation
5 Guides authored
USF Tampa, Team 11-2, Cheng Spring 2016 Member of USF Tampa, Team 11-2, Cheng Spring 2016
USFT-CHENG-S16S11G2
4 Members
72 Guides authored
13 Guide Comments
were i can buy a new battrery?
Joao lemos - Reply Share
likea g6 - Reply Share
Fanie Schoeman - Reply Share
Great guide. Detail was appreciated. I bought my battery at Newegg.com Item#: 9SIA3HK6018406. Thank you.
hale1730 - Reply Share
I just managed to find a replacement battery for the older JBL Flip2 , which has a LI-ion battery (just three cables with a different connector) for in this feature just the newer Lipo battery is covered:
This is the right battery for the early version:
https://www.amazon.de/gp/aw/d/B002XCR3UI...
it has a different connector , so soldering the old connector to the new battery is required: Easy enough, since the colors are the same - yellow to yellow , black-black and red-red.
it‘s a tiny bit wider so with a knife the side holders have to be cut out a little, you will see when you receive the battery.
open it up first and you will see which version you have, the LIPo version has the connector at the front as pictured above, the LI-ion version has a 3pin connector at the backside of the PCB.
fir this version you need a LI-ion battery as in the link above.
Everything else is just as described above - ists such a great little speaker and Im happy that it plays again… ;-)
Klaus - Reply Share
Past 24 Hours: 14
Past 7 Days: 76
Past 30 Days: 334
All Time: 39,422
