Up to 20% off select tools
JBL Clip Plus Microphone Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
104
All Time:
2,769
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 minutes
Difficulty: Difficult
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide will focus on removing the microphone.
    1. JBL Clip Plus Microphone Replacement, Battery: step 1, image 1 of 1
      Tool used on this step:
      $3.99
      Buy
      • Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
      Ask FixBot
    2. JBL Clip Plus Microphone Replacement: step 2, image 1 of 1
      • There will be three 6mm philips head screws under that rubber bumper, remove these three screws.
      Ask FixBot
    3. JBL Clip Plus Microphone Replacement: step 3, image 1 of 1
      • The back cover should lift open easily and the components should be visible.
      Ask FixBot
    4. JBL Clip Plus Microphone Replacement: step 4, image 1 of 1
      • The battery is adhered to the back cover of the JBL Clip Plus, slowly lift the battery away from the case, using a spudger to pry the battery away from the adhesive.
      Ask FixBot
    5. JBL Clip Plus Microphone Replacement: step 5, image 1 of 1
      • Remove the three 7mm philips head screws on the outer edges of the device.
      Ask FixBot
    6. JBL Clip Plus Microphone Replacement: step 6, image 1 of 1
      • Use the plastic prying tool to gently remove the face of the speaker from the body.
      Ask FixBot
    7. JBL Clip Plus Microphone Replacement: step 7, image 1 of 1
      • Use the spudger tool to gently scrape away the adhesive holding in the microphone.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      Ask FixBot
    8. JBL Clip Plus Microphone Replacement: step 8, image 1 of 1
      • Gently push the motherboard away from the microphone, this will allow you to remove the microphone.
      Ask FixBot
    9. JBL Clip Plus Microphone Replacement: step 9, image 1 of 1
      • Gently push the motherboard out from the frame of the JBL Clip Plus, this requires some force.
      Ask FixBot
    10. JBL Clip Plus Microphone Replacement: step 10, image 1 of 1
      • There are three solder points that need to be desoldered.
      • If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
      Ask FixBot
    1. JBL Clip Plus Microphone Replacement, Microphone: step 11, image 1 of 1
      Ask FixBot
Author
with
Noah Pauk
809 Reputation
3 Guides authored
IUPUI, Team 3-4, Baechle Spring 2016 Member of IUPUI, Team 3-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G4
4 Members
36 Guides authored
1 Guide Comment
Love the sound of this speaker but I would like to disable the bluetooth signals. I only need and use the cable connection. I have contacted the manufacturer about this and they said the bluetooth cannot be disabled at the present set-up. Would you please show me how to disable or remove the bluetooth?
Mic - Reply Share
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 104
All Time: 2,769
