Up to 20% off select tools
JBL Clip Plus Battery Replacement
Views: 29K
View statistics:
Past 24 Hours:
10
Past 7 Days:
39
Past 30 Days:
179
All Time:
29,301
Comments: 20
4 comments on steps, 16 guide comments.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The battery in the JBL Clip Plus is rechargeable. If the battery does not work, you will notice that the device does not stay on as long as it used to or wont turn on at all. If this is the case the battery will have to be replaced. The device will be taken apart and the battery will be removed and replaced.
    1. JBL Clip Plus Battery Replacement, Battery: step 1, image 1 of 1
      Tool used on this step:
      $3.99
      Buy
      • Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
      Ask FixBot
    2. JBL Clip Plus Battery Replacement: step 2, image 1 of 1
      • There will be three 6mm philips head screws under that rubber bumper, remove these three screws.
      Ask FixBot
    3. JBL Clip Plus Battery Replacement: step 3, image 1 of 1
      • The back cover should lift open easily and the components should be visible.
      Ask FixBot
    4. JBL Clip Plus Battery Replacement: step 4, image 1 of 1
      • The battery is adhered to the back cover of the JBL Clip Plus, slowly lift the battery away from the case, using a spudger to pry the battery away from the adhesive.
      Ask FixBot
    5. JBL Clip Plus Battery Replacement: step 5, image 1 of 1
      • Remove the three 7mm philips head screws on the outer edges of the device.
      Ask FixBot
    6. JBL Clip Plus Battery Replacement: step 6, image 1 of 1
      • Use the plastic prying tool to gently remove the face of the speaker from the body.
      Ask FixBot
    7. JBL Clip Plus Battery Replacement: step 7, image 1 of 1
      • Use the spudger tool to gently scrape away the adhesive holding in the microphone.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      Ask FixBot
    8. JBL Clip Plus Battery Replacement: step 8, image 1 of 1
      • Gently push the motherboard away from the microphone, this will allow you to remove the microphone.
      Ask FixBot
    9. JBL Clip Plus Battery Replacement: step 9, image 1 of 1
      • Gently push the motherboard out from the frame of the JBL Clip Plus, this requires some force.
      Ask FixBot
    10. JBL Clip Plus Battery Replacement: step 10, image 1 of 1
      • There are three solder points that need to be desoldered.
      • If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
      Ask FixBot
15 other people completed this guide.
Author
with
Noah Pauk
809 Reputation
3 Guides authored
IUPUI, Team 3-4, Baechle Spring 2016 Member of IUPUI, Team 3-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G4
4 Members
36 Guides authored
16 Guide Comments
Is it possible if replaced with a battery from cellphones with higher AmH rating?
Patrick Ignacio - Reply Share
Unfortunately, it would be hard to find a cell battery this small. The original battery is 2" x 1 1/8" x 1/8". My samsung S3 battery is 2 1/2" x 2" x 3/16", so is far from fitting. If you were ok with shaving the molded battery holder down, you could probably fit one that's 2" x 1 1/2" x 1/4" or so (the thickness tolerance is hard to tell), but it would be a lot of work. I think I might just buy a speaker that has good battery reputation (i.e., NOT JBL).
Kael Lumen - Reply Share
man need to replace the speaker were can i buy just that?
ruitherock - Reply Share
I think Id rather just buy a different speaker.
Lynne Norris - Reply Share
"No parts required."
Seriously? How about a new battery!
Also, mentioning the battery model or a link to a replacement battery would have been very useful.
Dan M - Reply Share
Past 24 Hours: 10
Past 7 Days: 39
Past 30 Days: 179
All Time: 29,301
