JBL Clip 4 USB-C Charging Port Replacement
    1. JBL Clip 4 USB-C Charging Port Replacement, Front Grill: step 1, image 1 of 1
      • Remove the front grill with a pry tool. The front grill is glued onto the device.
      Ask FixBot
    2. JBL Clip 4 USB-C Charging Port Replacement: step 2, image 1 of 1
      • Now you just need to pry it off using your chosen tool and it should come off easily leaving you with the front grill separated from the device. Your device should look like this after removing the front grill.
      Ask FixBot
    1. JBL Clip 4 USB-C Charging Port Replacement, Back Housing: step 3, image 1 of 1
      • First, you must unscrew the 5 Phillip head screws (6mm) around the edge of the device.
      Ask FixBot
    2. JBL Clip 4 USB-C Charging Port Replacement: step 4, image 1 of 1
      • Now with the unscrewed front and back housing, you should see some cables that connect between the two. Simply unplug these cables and the back housing will come apart from the front.
      Ask FixBot
    1. JBL Clip 4 USB-C Charging Port Replacement, Battery: step 5, image 1 of 1
      • The battery connects into the motherboard, and it is inside the black box shaped part that has a cable connecting into the motherboard. You must disconnect the cable connecting the battery to the motherboard.
      Ask FixBot
    2. JBL Clip 4 USB-C Charging Port Replacement: step 6, image 1 of 1
      • Now all you need to do is pull the battery out of the case its in and you have successfully disconnected the battery from the device.
      Ask FixBot
    1. JBL Clip 4 USB-C Charging Port Replacement, USB-C Charging Port: step 7, image 1 of 2 JBL Clip 4 USB-C Charging Port Replacement, USB-C Charging Port: step 7, image 2 of 2
      • At the bottom of the front housing is the USB-C Charging Port. It is held together by two Phillip head screws (3mm) on the left and right of the USB-C Charging Port. You need to remove the screws with a 0 Phillips head screwdriver.
      • Now you can remove the USB-C Charging Port.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Trey Adao
628 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 106
All Time: 304
