Introduction
This is how you replace a JBL Clip 4 battery. You may need to do this if your device is not properly holding charge, or it runs out of battery quickly.
Warning: If your battery is swollen be careful and do not puncture the battery as that can lead to hazards. Do not try to replace the battery when the device is hot.
Remove the front grill with a pry tool. The front grill is glued onto the device.
First, you must unscrew the 5 Phillip head screws (6mm) around the edge of the device.
The battery connects into the motherboard, and it is inside the black box shaped part that has a cable connecting into the motherboard. You must disconnect the cable connecting the battery to the motherboard.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
