JBL Clip 3 Speaker Replacement
  1. JBL Clip 3 Speaker Replacement, Speaker Grill: step 1, image 1 of 2 JBL Clip 3 Speaker Replacement, Speaker Grill: step 1, image 2 of 2
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
    Ask FixBot
  2. JBL Clip 3 Speaker Replacement, Speaker Housing: step 2, image 1 of 2 JBL Clip 3 Speaker Replacement, Speaker Housing: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
    Ask FixBot
  3. JBL Clip 3 Speaker Replacement: step 3, image 1 of 1
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
    Ask FixBot
  4. JBL Clip 3 Speaker Replacement: step 4, image 1 of 2 JBL Clip 3 Speaker Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
    Ask FixBot
  5. JBL Clip 3 Speaker Replacement, Internal Speaker: step 5, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the two 6.3 mm screws.
    Ask FixBot
  6. JBL Clip 3 Speaker Replacement: step 6, image 1 of 1
    Buy
    • Firmly grip the speaker connection plug with tweezers and pull it straight up, perpendicular to the motherboard, to release it.
    Ask FixBot
  7. JBL Clip 3 Speaker Replacement: step 7, image 1 of 1
    • Lift the speaker out of the housing.
    Ask FixBot
Tyler Molden
497 Reputation
4 Guides authored
3 Guide Comments
Dear Mr. Molden,
Thank you for sharing!
Do you, by any chance, have a part# for that speaker and/or know where to purchase a replacement one?
Tks in advance!
marcelo_kalil@hotmail.com
mkalil - Reply Share
Excelente información, dónde puedo conseguir altavoz de repuesto ?
Juan López Rodríguez - Reply Share
The front protective cover of my CLIP3 Bluetooth speaker fell off and is lost. Does anyone know where I can get a replacement?
Kym kymfaull@gmail.com
K Faull - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 100
All Time: 4,851
