JBL Clip 3 Motherboard Replacement
  1. JBL Clip 3 Motherboard Replacement, Speaker Grill: step 1, image 1 of 2 JBL Clip 3 Motherboard Replacement, Speaker Grill: step 1, image 2 of 2
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
    Ask FixBot
  2. JBL Clip 3 Motherboard Replacement, Speaker Housing: step 2, image 1 of 2 JBL Clip 3 Motherboard Replacement, Speaker Housing: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
    Ask FixBot
  3. JBL Clip 3 Motherboard Replacement: step 3, image 1 of 1
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
    Ask FixBot
  4. JBL Clip 3 Motherboard Replacement: step 4, image 1 of 2 JBL Clip 3 Motherboard Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
    Ask FixBot
  5. JBL Clip 3 Motherboard Replacement, Carabiner Clip: step 5, image 1 of 2 JBL Clip 3 Motherboard Replacement, Carabiner Clip: step 5, image 2 of 2
    • Lift the metal carabiner clip from the speaker housing.
    • They are not glued together and should separate easily.
    • There are alignment tabs on the clip so the whole assembly will only reassemble in one orientation.
    Ask FixBot
  6. JBL Clip 3 Motherboard Replacement, Motherboard: step 6, image 1 of 2 JBL Clip 3 Motherboard Replacement, Motherboard: step 6, image 2 of 2
    Buy
    • Use a pair of tweezers to release the two cable connections from the motherboard.
    • The wires connecting to the battery are not very long, so be careful when removing them.
    Ask FixBot
  7. JBL Clip 3 Motherboard Replacement: step 7, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the four screws.
    Ask FixBot
  8. JBL Clip 3 Motherboard Replacement: step 8, image 1 of 2 JBL Clip 3 Motherboard Replacement: step 8, image 2 of 2
    • Lift the motherboard away from the speaker housing.
    • Desolder the two contact points.
    Ask FixBot
Tyler Molden
497 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 38
All Time: 1,551
