JBL Clip 2 Speaker Replacement
    1. JBL Clip 2 Speaker Replacement, Speaker: step 1, image 1 of 1
      • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
      • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
      Ask FixBot
    2. JBL Clip 2 Speaker Replacement: step 2, image 1 of 1
      • There will be six 3 mm T8 screws under the cap, remove these six screws.
      Ask FixBot
    3. JBL Clip 2 Speaker Replacement: step 3, image 1 of 1
      • The front cover will lift open easily and the components will be visible.
      Ask FixBot
    4. JBL Clip 2 Speaker Replacement: step 4, image 1 of 1
      • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
      • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
      Ask FixBot
5 other people completed this guide.
Michael Hong
1,095 Reputation
5 Guides authored
UW Tacoma, Team 2-2, Rose Winter 2017 Member of UW Tacoma, Team 2-2, Rose Winter 2017
UWT-ROSE-W17S2G2
4 Members
60 Guides authored
6 Guide Comments
If no parts are required what are you replacing the speaker with?
Tom - Reply Share
Tom is right you know!
edward felix - Reply Share
The grill was glued into the T8 recesses. It needs glue to resemble. But how not to ruin the T8 heads for future work?
Gus Cannon - Reply Share
please we need to know where we can buy replacement speakers thanks email: chris.vargasrobles@gmail.com
chris robles - Reply Share
Hi, where I can buy the speaker please? Thank you.
Govan - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 71
All Time: 7,965
