JBL Clip 2 Motherboard Replacement
    1. JBL Clip 2 Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
      • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
      Ask FixBot
    2. JBL Clip 2 Motherboard Replacement: step 2, image 1 of 1
      • There will be six 3 mm T8 screws under the cap, remove these six screws.
      • If you are not trying to replace the speaker please ignore the two middle 3 mm T8 screws during this procedure.
      Ask FixBot
    3. JBL Clip 2 Motherboard Replacement: step 3, image 1 of 1
      • The front cover will lift open easily and the components will be visible.
      Ask FixBot
    4. JBL Clip 2 Motherboard Replacement: step 4, image 1 of 1
      • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
      • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
      Ask FixBot
    5. JBL Clip 2 Motherboard Replacement: step 5, image 1 of 1
      • There will be four 3 mm T8 screws holding the motherboard in place, remove these four screws.
      Ask FixBot
    6. JBL Clip 2 Motherboard Replacement: step 6, image 1 of 1
      • The motherboard is now exposed, and to extract it you must now desoder the eight connection points to the battery, audio AUX cord, and the Mic.
      • If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
      Ask FixBot
2 other people completed this guide.
Michael Hong
1,095 Reputation
5 Guides authored
UW Tacoma, Team 2-2, Rose Winter 2017 Member of UW Tacoma, Team 2-2, Rose Winter 2017
UWT-ROSE-W17S2G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 46
All Time: 4,271
