Tools
Spudger4.9
Introduction
Go to step 1 ↓This guide is intended to help fix buttons that are not functioning correctly.
Make sure the device is powered off before you begin to disassemble the speaker.
Remove the trim from the speaker using a jimmy or metal spudger.
The first photo shows a metal spudger. Use a plastic spudger instead to avoid damaging the battery.
Use the flat end of a plastic spudger to gently lift the end of the battery opposite the cable. Lift it only far enough to access the screw underneath. Do not bend the battery or strain its cable.
Use a Phillips #2 screwdriver to remove the 16 mm screw beneath the battery.
Use a Phillips #2 screwdriver to remove the four remaining 16 mm screws securing the white plastic housing.
Keep these screws separate from the shorter battery-cover screws.
The rear housing is still connected to the speaker by cables. Do not pull the housing halves apart.
Starting at the corner shown in the photos, carefully insert a metal spudger into the seam between the rear housing and the speaker.
Work along the seam to release the adhesive. Avoid inserting the tool deeply into the speaker, where it could damage internal components.
Open the rear housing only far enough to access the connectors.
Support the rear housing so that it does not hang from its cables.
Disconnect the three white connectors from the motherboard. Grip the connector housings rather than pulling on the wires. Do not force the connectors.
Remove the rear housing.
Locate the buttons on top of the device. Peel the white piece of tape located along the side of this button membrane.
4 other people completed this guide.
2 Guide Comments
conseguiste el boton de repuesto?
Por favor, disculpe mis errores:
"No puedo encontrar un nuevo reemplazo. Compra uno roto. Utilice el botón de la que se rompe."
