JBL Charge 5 Fabric Case Replacement
    1. JBL Charge 5 Fabric Case Replacement, Fabric Case: step 1, image 1 of 3 JBL Charge 5 Fabric Case Replacement, Fabric Case: step 1, image 2 of 3 JBL Charge 5 Fabric Case Replacement, Fabric Case: step 1, image 3 of 3
      • Ensure that the device is fully powered off and no cables are attached before proceeding with the repair.
      • This fabric cover is secured with plastic clips only. Depending on the model, the cover may be secured by both plastic clips and screws.
      • Insert the flat end of the Jimmy into the seam located between the fabric cover on the right side of the seam.
      • Pry upward on the fabric cover to release plastic clips on the right side of the seam.
      Ask FixBot
    2. JBL Charge 5 Fabric Case Replacement: step 2, image 1 of 3 JBL Charge 5 Fabric Case Replacement: step 2, image 2 of 3 JBL Charge 5 Fabric Case Replacement: step 2, image 3 of 3
      • Insert the flat end of the Jimmy into the seam between the fabric cover at the center of the seam and the left side of the seam.
      • Use the Jimmy to pry open the edge with the rubber texture, releasing the remaining plastic clips.
      Ask FixBot
    3. JBL Charge 5 Fabric Case Replacement: step 3, image 1 of 3 JBL Charge 5 Fabric Case Replacement: step 3, image 2 of 3 JBL Charge 5 Fabric Case Replacement: step 3, image 3 of 3
      • Use your hands to gently open the two halves of the casing and slide the fabric cover off of the interior housing.
      Ask FixBot
4 other people completed this guide.
3 Guide Comments
Dónde puedo encontrar a la venta esos reemplazos
Jose “Joseso” Hernandez - Reply Share
Where do I find the replacement part?
Peyton Orlowsky - Reply Share
아니 어디서 구하냐고, 일안하네?
J_ Minhyung - Reply Share
Past 24 Hours: 11
Past 7 Days: 73
Past 30 Days: 284
All Time: 6,264
