Up to 20% off select tools
JBL Charge 5 Buttons Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
40
Past 30 Days:
160
All Time:
2,239
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 35 - 55 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Welcome to our guide for replacing the buttons on your JBL Charge 5 Speaker. This guide is for the TT version, but it's applicable with slight variations for other models. If you're facing issues like unresponsiveness, sticking, or physical damage, follow these steps to regain full control of your device's functionality.
For additional troubleshooting information, check out the JBL Charge 5 Troubleshooting page.
Note: This repair requires intermediate technical skills.
If unfamiliar, seek professional help or contact JBL's customer support.
Guide Highlights:
  • Detailed step-by-step instructions with illustrations.
  • Read the guide entirely before starting.
  • Power off your JBL Charge 5 Speaker before repairs.
Check Warranty:
  • If under warranty, contact the manufacturer or an authorized service center.
Pre-Repair Tips:
  • Handle electronic components with care.
  • Note connectors or ribbons for disconnection/reconnection.
  • Work in a clean, well-illuminated space.
Post-Repair:
  • Conduct a functionality test.
  • Test each button individually for responsiveness and overall usability changes.
Before you begin the repair, power off your device and unplug the charger.
    1. JBL Charge 5 Buttons Replacement, Fabric Case: step 1, image 1 of 3 JBL Charge 5 Buttons Replacement, Fabric Case: step 1, image 2 of 3 JBL Charge 5 Buttons Replacement, Fabric Case: step 1, image 3 of 3
      • Ensure that the device is fully powered off and no cables are attached before proceeding with the repair.
      • This fabric cover is secured with plastic clips only. Depending on the model, the cover may be secured by both plastic clips and screws.
      • Insert the flat end of the Jimmy into the seam located between the fabric cover on the right side of the seam.
      • Pry upward on the fabric cover to release plastic clips on the right side of the seam.
      Ask FixBot
    2. JBL Charge 5 Buttons Replacement: step 2, image 1 of 3 JBL Charge 5 Buttons Replacement: step 2, image 2 of 3 JBL Charge 5 Buttons Replacement: step 2, image 3 of 3
      • Insert the flat end of the Jimmy into the seam between the fabric cover at the center of the seam and the left side of the seam.
      • Use the Jimmy to pry open the edge with the rubber texture, releasing the remaining plastic clips.
      Ask FixBot
    3. JBL Charge 5 Buttons Replacement: step 3, image 1 of 3 JBL Charge 5 Buttons Replacement: step 3, image 2 of 3 JBL Charge 5 Buttons Replacement: step 3, image 3 of 3
      • Use your hands to gently open the two halves of the casing and slide the fabric cover off of the interior housing.
      Ask FixBot
    1. JBL Charge 5 Buttons Replacement, Buttons: step 4, image 1 of 2 JBL Charge 5 Buttons Replacement, Buttons: step 4, image 2 of 2
      • Use an iFixit opening tool, to softly pry open each side of the button cover.
      • By removing the rubber button cover, the adhesives will break. This may cause the device to lose its waterproof feature.
      Ask FixBot
    2. JBL Charge 5 Buttons Replacement: step 5, image 1 of 3 JBL Charge 5 Buttons Replacement: step 5, image 2 of 3 JBL Charge 5 Buttons Replacement: step 5, image 3 of 3
      • Use a plastic spudger, and softly pry up on the sides of the button control board to remove it from the slot.
      • Be cautious and don't pull the board all of the way out. The board is connected to the device by a ribbon cable.
      Ask FixBot
    3. JBL Charge 5 Buttons Replacement: step 6, image 1 of 3 JBL Charge 5 Buttons Replacement: step 6, image 2 of 3 JBL Charge 5 Buttons Replacement: step 6, image 3 of 3
      • Pinch the no-fuss ribbon cable connector, and gently pull the cable out to disconnect it from the board.
      • Remove the button board.
      Ask FixBot
Author
with
Kat Whaley
1,144 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 40
Past 30 Days: 160
All Time: 2,239
