JBL Charge 4 Speaker Replacement
    1. JBL Charge 4 Speaker Replacement, Speaker Grill: step 1, image 1 of 1
      • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
      • Pry away from yourself towards the back of the speaker to release the clip.
      • Repeat this process for the clip on the other side.
      Ask FixBot
    2. JBL Charge 4 Speaker Replacement: step 2, image 1 of 2 JBL Charge 4 Speaker Replacement: step 2, image 2 of 2
      • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
      Ask FixBot
    3. JBL Charge 4 Speaker Replacement: step 3, image 1 of 1
      • Pull apart both sides of the grille.
      • Lift the cover off of the speaker.
      Ask FixBot
    1. JBL Charge 4 Speaker Replacement, Passive Bass Radiators: step 4, image 1 of 2 JBL Charge 4 Speaker Replacement, Passive Bass Radiators: step 4, image 2 of 2
      • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
      • Repeat this process on the other clips around the radiator to release it from the frame.
      Ask FixBot
    2. JBL Charge 4 Speaker Replacement: step 5, image 1 of 2 JBL Charge 4 Speaker Replacement: step 5, image 2 of 2
      • Push the radiator off of the frame of the device.
      • Repeat on the other side.
      • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
      Ask FixBot
    1. JBL Charge 4 Speaker Replacement, Speaker: step 6, image 1 of 2 JBL Charge 4 Speaker Replacement, Speaker: step 6, image 2 of 2
      • Flip the device so that the speaker faces you.
      • Remove the four 8mm Phillips #1 screws.
      Ask FixBot
    2. JBL Charge 4 Speaker Replacement: step 7, image 1 of 1
      • Gently pull out the speaker.
      Ask FixBot
    3. JBL Charge 4 Speaker Replacement: step 8, image 1 of 2 JBL Charge 4 Speaker Replacement: step 8, image 2 of 2
      • Desolder the red and black wires.
      • A guide for soldering and desoldering can be found here.
      Ask FixBot
13 other people completed this guide.
Rohith Dara
429 Reputation
1 Guide authored
Cal Poly, Team S1-G1, White Winter 2019 Member of Cal Poly, Team S1-G1, White Winter 2019
CPSU-WHITE-W19S1G1
4 Members
84 Guides authored
12 Guide Comments
Perfect - But where to get the replacement speaker ??? I’ve searched whole web. Please give me the info about replacement speaker diaphragm. Regards, T
Tadej Tomašič - Reply Share
Jbl charge 4
carlos maltez - Reply Share
Jbl charge 4 Led indicator board G ribbon cable authentic
Past 24 Hours: 10
Past 7 Days: 58
Past 30 Days: 202
All Time: 28,233
