JBL Charge 4 Charging Port Bay Replacement
    1. JBL Charge 4 Charging Port Bay Replacement, Speaker Grill: step 1, image 1 of 1
      • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
      • Pry away from yourself towards the back of the speaker to release the clip.
      • Repeat this process for the clip on the other side.
      Ask FixBot
    2. JBL Charge 4 Charging Port Bay Replacement: step 2, image 1 of 2 JBL Charge 4 Charging Port Bay Replacement: step 2, image 2 of 2
      • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
      Ask FixBot
    3. JBL Charge 4 Charging Port Bay Replacement: step 3, image 1 of 1
      • Pull apart both sides of the grille.
      • Lift the cover off of the speaker.
      Ask FixBot
    1. JBL Charge 4 Charging Port Bay Replacement, Passive Bass Radiators: step 4, image 1 of 2 JBL Charge 4 Charging Port Bay Replacement, Passive Bass Radiators: step 4, image 2 of 2
      • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
      • Repeat this process on the other clips around the radiator to release it from the frame.
      Ask FixBot
    2. JBL Charge 4 Charging Port Bay Replacement: step 5, image 1 of 2 JBL Charge 4 Charging Port Bay Replacement: step 5, image 2 of 2
      • Push the radiator off of the frame of the device.
      • Repeat on the other side.
      • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
      Ask FixBot
    1. JBL Charge 4 Charging Port Bay Replacement, Charging Port Bay: step 6, image 1 of 2 JBL Charge 4 Charging Port Bay Replacement, Charging Port Bay: step 6, image 2 of 2
      • Remove the two 6mm Phillips #0 screws from either side to remove the port bay cover.
      Ask FixBot
    2. JBL Charge 4 Charging Port Bay Replacement: step 7, image 1 of 1
      • There are two hooks that attach the opposite side of the port bay cover to the device. Slide the cover back and off the hooks.
      • Remove the port bay cover.
      Ask FixBot
    3. JBL Charge 4 Charging Port Bay Replacement: step 8, image 1 of 2 JBL Charge 4 Charging Port Bay Replacement: step 8, image 2 of 2
      • Remove the six 6mm Phillips #0 screws.
      Ask FixBot
    4. JBL Charge 4 Charging Port Bay Replacement: step 9, image 1 of 2 JBL Charge 4 Charging Port Bay Replacement: step 9, image 2 of 2
      • Before removing port bay you must detach the connecting tabs on either side of the device.
      • Press on the tab and gently pull out the wire connector.
      Ask FixBot
    5. JBL Charge 4 Charging Port Bay Replacement: step 10, image 1 of 2 JBL Charge 4 Charging Port Bay Replacement: step 10, image 2 of 2
      • Remove the second connector on the opposite side by gently pulling it out.
      Ask FixBot
    6. JBL Charge 4 Charging Port Bay Replacement: step 11, image 1 of 1
      • Remove the port bay from the device and place the device to the side.
      Ask FixBot
    7. JBL Charge 4 Charging Port Bay Replacement: step 12, image 1 of 2 JBL Charge 4 Charging Port Bay Replacement: step 12, image 2 of 2
      • Remove the three 9mm Phillips #0 screws from the board.
      Ask FixBot
    8. JBL Charge 4 Charging Port Bay Replacement: step 13, image 1 of 2 JBL Charge 4 Charging Port Bay Replacement: step 13, image 2 of 2
      • Using the plastic opening tool, lift the board from the port bay holder.
      Ask FixBot
    9. JBL Charge 4 Charging Port Bay Replacement: step 14, image 1 of 2 JBL Charge 4 Charging Port Bay Replacement: step 14, image 2 of 2
      • Choose which port you want to replace.
      • Turn the board around and desolder the connection to remove the chosen port.
      • A guide for soldering and desoldering can be found here.
      Ask FixBot
15 other people completed this guide.
Zachary Colwell
2,239 Reputation
5 Guides authored
Cal Poly, Team S1-G1, White Winter 2019 Member of Cal Poly, Team S1-G1, White Winter 2019
CPSU-WHITE-W19S1G1
4 Members
84 Guides authored
10 Guide Comments
Does anybody know which exact ports I have to get? There are a ton of different models out there.
Ulpi - Reply Share
You can purchase charging sockets from ebay by searching for "jbl charge 4 usb-c port" (without the quotation marks) or if you don't feel like replacing the charging port yourself, there are mail-in repair services available also.
Simon - Reply Share
Ijust change the battery on my jbl charge4 it is not powering on or even charging what going on?
pipask1 - Reply Share
Ersatzteil:
✅ JBL Charge 4 Bluetooth Lautsprecher Micro USB C Buchse Ladebuchse Connector
https://www.ebay.de/itm/164897748374
Falls Sie beim Austausch der Buchse Hilfe benötigen:
✅ REPARATUR Austausch Micro USB C Buchse Ladebuchse Anschluss Port JBL Charge 4
https://www.ebay.de/itm/164975006896
PC-Solutions - Reply Share
I could not change the USB-C myself so had it soldered in a shop for me. For the rest of the procedure, I could perform it alone thanks to this guide, now the device works again. Thanks!
sylkys - Reply Share
Past 24 Hours: 8
Past 7 Days: 86
Past 30 Days: 350
All Time: 31,404
