JBL Charge 3 Front Cover Replacement
    1. JBL Charge 3 Front Cover Replacement, Front Cover: step 1, image 1 of 3 JBL Charge 3 Front Cover Replacement, Front Cover: step 1, image 2 of 3 JBL Charge 3 Front Cover Replacement, Front Cover: step 1, image 3 of 3
      • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
      • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
      • Repeat this process for all four edges of the front cover.
      Ask FixBot
    2. JBL Charge 3 Front Cover Replacement: step 2, image 1 of 1
      • Pull apart your cover gently from both sides and remove it from the speaker housing.
      • There are screws around the foot of the device that may need loosening to be able to unclip the other side of the cover.
      • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
      • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
      Ask FixBot
6 other people completed this guide.
Aidan Hays
4,382 Reputation
2 Guides authored
Cal Poly, Team S13-G1, White Fall 2018 Member of Cal Poly, Team S13-G1, White Fall 2018
CPSU-WHITE-F18S13G1
3 Members
48 Guides authored
2 Guide Comments
where can i buy a new front cover for mine? mine has got cracked
Cammy Innes - Reply Share
It seems there may be different versions of Charge 3 covers in existence, as when I opened mine (carefully with a slim screwdriver) I was presented with a single cross head screw on each end which was holding one of the ends of the cover in place. I could remove the top end at both ends, but had to unscrew these screws to get the other end off. It was easy, just deviates from this guide quite a bit!
Thomas Hall - Reply Share
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 140
All Time: 12,701
