JBL Charge 3 Battery Replacement
    1. JBL Charge 3 Battery Replacement, Front Cover: step 1, image 1 of 3 JBL Charge 3 Battery Replacement, Front Cover: step 1, image 2 of 3 JBL Charge 3 Battery Replacement, Front Cover: step 1, image 3 of 3
      • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
      • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
      • Repeat this process for all four edges of the front cover.
      Ask FixBot
    2. JBL Charge 3 Battery Replacement: step 2, image 1 of 1
      • Pull apart your cover gently from both sides and remove it from the speaker housing.
      • There are screws around the foot of the device that may need loosening to be able to unclip the other side of the cover.
      • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
      • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
      Ask FixBot
    1. JBL Charge 3 Battery Replacement, Passive Radiators: step 3, image 1 of 3 JBL Charge 3 Battery Replacement, Passive Radiators: step 3, image 2 of 3 JBL Charge 3 Battery Replacement, Passive Radiators: step 3, image 3 of 3
      • Remove the two 8mm Phillips #1 screws from the tabs.
      • NOTE: There may be only one screw.
      Ask FixBot
    2. JBL Charge 3 Battery Replacement: step 4, image 1 of 2 JBL Charge 3 Battery Replacement: step 4, image 2 of 2
      • Insert the plastic opening tools underneath both tabs.
      Ask FixBot
    3. JBL Charge 3 Battery Replacement: step 5, image 1 of 1
      • Twist and pull open the passive radiator. The left radiator twists off clockwise; the right counterclockwise.
      Ask FixBot
    4. JBL Charge 3 Battery Replacement: step 6, image 1 of 2 JBL Charge 3 Battery Replacement: step 6, image 2 of 2
      • Repeat all previous steps for the other passive radiator.
      • NOTE: only the right radiator needs to be removed for changing the battery.
      Ask FixBot
    1. JBL Charge 3 Battery Replacement, Battery: step 7, image 1 of 3 JBL Charge 3 Battery Replacement, Battery: step 7, image 2 of 3 JBL Charge 3 Battery Replacement, Battery: step 7, image 3 of 3
      • Remove the six 8mm Phillips #1 screws from the outer battery cover.
      • Peel the outer battery cover away from the speaker housing.
      Ask FixBot
    2. JBL Charge 3 Battery Replacement: step 8, image 1 of 3 JBL Charge 3 Battery Replacement: step 8, image 2 of 3 JBL Charge 3 Battery Replacement: step 8, image 3 of 3
      • Remove the seven 8mm Phillips #1 screws from interior battery cover.
      • Remove the interior battery cover.
      Ask FixBot
    3. JBL Charge 3 Battery Replacement: step 9, image 1 of 2 JBL Charge 3 Battery Replacement: step 9, image 2 of 2
      • Pull gently to disconnect the bundled cable connector in the side of the speaker. This action will separate the battery from the motherboard.
      Ask FixBot
    4. JBL Charge 3 Battery Replacement: step 10, image 1 of 1
      • Pull the battery and battery cable out from their housing.
      Ask FixBot
154 other people completed this guide.
Jack Ng
2,446 Reputation
4 Guides authored
35 Guide Comments
you legend. thank you so much! i was worried it was a seal unit!
Anthony Hilfischer - Reply Share
Super Anleitung! Hat der Akkutausch hat problemlos funktioniert!
Tomas Opmann - Reply Share
thank you so much :D
punkzmarc - Reply Share
Great Guide! Where can I get the foamy coating of the battery’s wires? Or what is the proper term?
Dom Heizmann - Reply Share
I saw one on youtube taking the one from the old battery and putting it on the new one
Dominik Spreuer - Reply Share
Past 24 Hours: 52
Past 7 Days: 316
Past 30 Days: 1,660
All Time: 274,002
