JBL Charge 2 Plus Passive Radiators Replacement
    1. JBL Charge 2 Plus Passive Radiators Replacement, Passive Radiators: step 1, image 1 of 2 JBL Charge 2 Plus Passive Radiators Replacement, Passive Radiators: step 1, image 2 of 2
      • Starting from the front side bottom left corner, use the nylon or metal spudger to lift the grille up from each of the four corners.
      • Follow the previous instruction to remove the back grille.
      Ask FixBot
    2. JBL Charge 2 Plus Passive Radiators Replacement: step 2, image 1 of 3 JBL Charge 2 Plus Passive Radiators Replacement: step 2, image 2 of 3 JBL Charge 2 Plus Passive Radiators Replacement: step 2, image 3 of 3
      • Unscrew the two .5 mm screws that hold the sub woofer in place.
      • Repeat the last step for the two screws on the back side.
      Ask FixBot
    3. JBL Charge 2 Plus Passive Radiators Replacement: step 3, image 1 of 2 JBL Charge 2 Plus Passive Radiators Replacement: step 3, image 2 of 2
      • Remove the four screws that hold the passive radiator in place
      Ask FixBot
    4. JBL Charge 2 Plus Passive Radiators Replacement: step 4, image 1 of 1
      • Pop the Passive Radiator off.
      Ask FixBot
    5. JBL Charge 2 Plus Passive Radiators Replacement: step 5, image 1 of 3 JBL Charge 2 Plus Passive Radiators Replacement: step 5, image 2 of 3 JBL Charge 2 Plus Passive Radiators Replacement: step 5, image 3 of 3
      • Repeat Step 2, 3 and 4 for the other passive radiator.
      Ask FixBot
7 other people completed this guide.
John Reynolds
3,354 Reputation
4 Guides authored
UMass Dartmouth, Team 4-1, Catania Fall 2015 Member of UMass Dartmouth, Team 4-1, Catania Fall 2015
UMASSD-CATANIA-F15S4G1
4 Members
60 Guides authored
3 Guide Comments
Where can the radiators be purchased?
Jennifer - Reply Share
When charging my charge 2+ 4 LED lights are blowing but 5th one is not blowing , 5th one blows when Bluetooth is on that is when speaker is on . I don't know what to do please help mail at jomonjohny140898@gmail.com
Jomon johny - Reply Share
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 50
All Time: 18,860
