JBL Charge 2 Plus Battery Replacement
    1. JBL Charge 2 Plus Battery Replacement, Passive Radiators: step 1, image 1 of 2 JBL Charge 2 Plus Battery Replacement, Passive Radiators: step 1, image 2 of 2
      • Starting from the front side bottom left corner, use the nylon or metal spudger to lift the grille up from each of the four corners.
      • Follow the previous instruction to remove the back grille.
      Ask FixBot
    2. JBL Charge 2 Plus Battery Replacement: step 2, image 1 of 3 JBL Charge 2 Plus Battery Replacement: step 2, image 2 of 3 JBL Charge 2 Plus Battery Replacement: step 2, image 3 of 3
      • Unscrew the two .5 mm screws that hold the sub woofer in place.
      • Repeat the last step for the two screws on the back side.
      Ask FixBot
    3. JBL Charge 2 Plus Battery Replacement: step 3, image 1 of 2 JBL Charge 2 Plus Battery Replacement: step 3, image 2 of 2
      • Remove the four screws that hold the passive radiator in place
      Ask FixBot
    4. JBL Charge 2 Plus Battery Replacement: step 4, image 1 of 1
      • Pop the Passive Radiator off.
      Ask FixBot
    5. JBL Charge 2 Plus Battery Replacement: step 5, image 1 of 3 JBL Charge 2 Plus Battery Replacement: step 5, image 2 of 3 JBL Charge 2 Plus Battery Replacement: step 5, image 3 of 3
      • Repeat Step 2, 3 and 4 for the other passive radiator.
      Ask FixBot
    1. JBL Charge 2 Plus Battery Replacement, Battery: step 6, image 1 of 2 JBL Charge 2 Plus Battery Replacement, Battery: step 6, image 2 of 2
      • Remove the battery wire from the circuit board by pulling it out gently on the side closest to the LCD light.
      Ask FixBot
    2. JBL Charge 2 Plus Battery Replacement: step 7, image 1 of 1
      • Remove the 6 screws that hold the white cover in place.
      Ask FixBot
    3. JBL Charge 2 Plus Battery Replacement: step 8, image 1 of 2 JBL Charge 2 Plus Battery Replacement: step 8, image 2 of 2
      • Use the plastic opening tool to remove the battery.
      Ask FixBot
80 other people completed this guide.
John Reynolds
3,354 Reputation
4 Guides authored
UMass Dartmouth, Team 4-1, Catania Fall 2015 Member of UMass Dartmouth, Team 4-1, Catania Fall 2015
UMASSD-CATANIA-F15S4G1
4 Members
60 Guides authored
40 Guide Comments
Great guide but where to source a battery for a JBL charge 2.
Mine failed, complained to Harman and they sent a new one and didn't want the old one so have a spare I'd like to get working.
Thanks in advance
Rob grist - Reply Share
Had my speaker for a month. It won't charge. Why did it only last a month and I have to get a new one? I'm not satisfied with the speaker for the price that I paid.
Jeanette dagastine - Reply Share
When I charge my jbl the light in tge power button turns on but when I press it the device does not respond. Please help me...
Tibetan Stoner - Reply Share
Try disconnecting the battery and plugging it in again.
MarelyOscar - Reply Share
I just had the same problem, the on/off led got stuck and couldn't get any sound or operation from any button. After different attempts a simultaneous pressing of the Phone together with the - and the + button brought my Charge2 to life again.
Javier G. Valdivia - Reply Share
Past 24 Hours: 9
Past 7 Days: 71
Past 30 Days: 252
All Time: 141,717
