JBL Charge 2 Battery Replacement
    1. JBL Charge 2 Battery Replacement, Battery: step 1, image 1 of 1
      • Remove the screen cover from the speaker using a metal spudger.
      Ask FixBot
    2. JBL Charge 2 Battery Replacement: step 2, image 1 of 2 JBL Charge 2 Battery Replacement: step 2, image 2 of 2
      • Using a Phillips #1 screwdriver (PH1), remove the (4) four 8mm screws.
      • Remove the end cap of the device. Repeat the same process to remove the other end cap.
      Ask FixBot
    3. JBL Charge 2 Battery Replacement: step 3, image 1 of 2 JBL Charge 2 Battery Replacement: step 3, image 2 of 2
      • To remove the end diaphragms, use a Phillips #1 screwdriver (PH1) and remove the (4) four 6mm screws.
      • Twist off the end cap and remove them from the device.
      Ask FixBot
    4. JBL Charge 2 Battery Replacement: step 4, image 1 of 2 JBL Charge 2 Battery Replacement: step 4, image 2 of 2
      • Use a Phillips #1 screwdriver (PH1) to remove the (2) two screws from the battery cover.
      • Pry away the plastic battery cover with a plastic spudger.
      Ask FixBot
    5. JBL Charge 2 Battery Replacement: step 5, image 1 of 1
      • Disconnect the battery connector with a plastic opening tool and wiggle the connector free.
      Ask FixBot
    6. JBL Charge 2 Battery Replacement: step 6, image 1 of 3 JBL Charge 2 Battery Replacement: step 6, image 2 of 3 JBL Charge 2 Battery Replacement: step 6, image 3 of 3
      • Scrape the battery wire sealant off with a plastic opening tool, and ensure it is free of the body of the speaker and wires.
      • Slide the battery free.
      Ask FixBot
13 other people completed this guide.
Mauzor Ilonzo
561 Reputation
3 Guides authored
USF Tampa, Team S2-G4, Passmore Fall 2017 Member of USF Tampa, Team S2-G4, Passmore Fall 2017
USFT-PASSMORE-F17S2G4
4 Members
36 Guides authored
3 Guide Comments
Thanks for the manual! Easy repair this way.
Jeroen Cox - Reply Share
The JBL Charge 2 I have only needs the rear screen to be taken off. Once removed, just unscrew the battery holder plate. No need to unscrew the bass speakers. The battery plate is pretty well protected against water entering. You have to remove some silicone caulking to take out the power plug. My speaker takes the “New” Charge 2 battery.
Rogelio Fernandez - Reply Share
Could you please suggest me where to buy battery for JBL Charge 2. Iam from Visakhapatnam, India. My mail vasudev.chiratla@gmail.com.
Vasudev Chiratla - Reply Share
Past 24 Hours: 9
Past 7 Days: 67
Past 30 Days: 278
All Time: 26,269
