Ivation IVWPDC20Y Motherboard Replacement
  1. Ivation IVWPDC20Y Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
    Ask FixBot
  2. Ivation IVWPDC20Y Motherboard Replacement: step 2, image 1 of 1
    • Apply a plastic opening tool to each of the corners and gently remove the casing
    • The front casing is held down by adhesive and may require additional work to remove
    • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
    Ask FixBot
  3. Ivation IVWPDC20Y Motherboard Replacement: step 3, image 1 of 1
    • Remove the five silver screws from the inner casing using the PH00 screwdriver bit
    Ask FixBot
  4. Ivation IVWPDC20Y Motherboard Replacement: step 4, image 1 of 1
    • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit
    • These screws are very small and easy to strip so apply consistent pressure when removing them
    Ask FixBot
  5. Ivation IVWPDC20Y Motherboard Replacement: step 5, image 1 of 1
    • Pry off back outer casing using the black spudger or the blue prying tools
    Ask FixBot
  6. Ivation IVWPDC20Y Motherboard Replacement: step 6, image 1 of 1
    • Carefully remove the screen from the silver casing using a prying tool or the black spudger
    • There is adhesive in the center of the screen, be sure not to bend it when applying pressure
    Ask FixBot
  7. Ivation IVWPDC20Y Motherboard Replacement: step 7, image 1 of 1
    • Gently push out the pins holding the orange tape down using the pointy end of the spudger
    • Screen and orange tape should slip out as a whole
    Ask FixBot
  8. Ivation IVWPDC20Y Motherboard Replacement: step 8, image 1 of 1
    • Remove three screws holding the silver screen casing to the motherboard using the PH00 bit screwdriver
    Ask FixBot
  9. Ivation IVWPDC20Y Motherboard Replacement: step 9, image 1 of 1
    • Remove three screws holding the motherboard into the casing using the PH00 bit screwdriver bit
    Ask FixBot
  10. Ivation IVWPDC20Y Motherboard Replacement: step 10, image 1 of 1
    • Gently lift the corner of the motherboard out
    • Everything should come out as one component free of the casing
    Ask FixBot
  11. Ivation IVWPDC20Y Motherboard Replacement: step 11, image 1 of 1
    • Remove the soldering on the three wires holding the flash bulb
    • The wires are different colors: red, white, and black
    Ask FixBot
  12. Ivation IVWPDC20Y Motherboard Replacement: step 12, image 1 of 1
    • Remove the two screws holding the lens assembly to the motherboard using the PH00 bit screwdriver
    Ask FixBot
  13. Ivation IVWPDC20Y Motherboard Replacement: step 13, image 1 of 1
    • Remove the soldering on the 3 wires that are connected to the lens unit
    Ask FixBot
  14. Ivation IVWPDC20Y Motherboard Replacement: step 14, image 1 of 1
    • Remove the three screws holding the button sensors to the battery casing using the PH00 screwdriver bit
    Ask FixBot
  15. Ivation IVWPDC20Y Motherboard Replacement: step 15, image 1 of 1
    • Remove soldering on the grouping of wires connecting the button sensors
    Ask FixBot
  16. Ivation IVWPDC20Y Motherboard Replacement: step 16, image 1 of 1
    • Lift screen to reveal wires underneath
    • Remove soldering connecting screen to the motherboard
    Ask FixBot
  17. Ivation IVWPDC20Y Motherboard Replacement: step 17, image 1 of 1
    • Gently pull orange tape from the motherboard
    Ask FixBot
  18. Ivation IVWPDC20Y Motherboard Replacement: step 18, image 1 of 1
    • Remove soldering from the two green wires connected to the motherboard
    Ask FixBot
  19. Ivation IVWPDC20Y Motherboard Replacement: step 19, image 1 of 1
    • Gently bend the capacitor upwards
    • Remove soldering from the two connectors
    Ask FixBot
Wendy Jones
225 Reputation
2 Guides authored
USF Tampa, Team 6-6, Eyestone Spring 2016 Member of USF Tampa, Team 6-6, Eyestone Spring 2016
USFT-EYESTONE-S16S6G6
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 735
