Ivation IVWPDC20Y Flash Bulb Replacement
    1. Ivation IVWPDC20Y Flash Bulb Replacement, Flash Bulb: step 1, image 1 of 1
      • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
      Ask FixBot
    2. Ivation IVWPDC20Y Flash Bulb Replacement: step 2, image 1 of 1
      • Apply a plastic opening tool to each of the corners and gently remove the casing
      • The front casing is held down by adhesive and may require additional work to remove
      • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
      Ask FixBot
    3. Ivation IVWPDC20Y Flash Bulb Replacement: step 3, image 1 of 1
      • Remove the five silver screws from the inner casing using the PH00 screwdriver bit
      Ask FixBot
    4. Ivation IVWPDC20Y Flash Bulb Replacement: step 4, image 1 of 1
      • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit
      • These screws are very small and easy to strip so apply consistent pressure when removing them
      Ask FixBot
    5. Ivation IVWPDC20Y Flash Bulb Replacement: step 5, image 1 of 1
      • Pry off back outer casing using the black spudger or the blue prying tools
      Ask FixBot
    6. Ivation IVWPDC20Y Flash Bulb Replacement: step 6, image 1 of 1
      • Carefully remove the screen from the silver casing using a prying tool or the black spudger
      • There is adhesive in the center of the screen, be sure not to bend it when applying pressure
      Ask FixBot
    7. Ivation IVWPDC20Y Flash Bulb Replacement: step 7, image 1 of 1
      • Gently push out the pins holding the orange tape down using the pointy end of the spudger
      • Screen and orange tape should slip out as a whole
      Ask FixBot
    8. Ivation IVWPDC20Y Flash Bulb Replacement: step 8, image 1 of 1
      • Remove three screws holding the silver screen casing to the motherboard using the PH00 bit screwdriver
      Ask FixBot
    9. Ivation IVWPDC20Y Flash Bulb Replacement: step 9, image 1 of 1
      • Remove three screws holding the motherboard into the casing using the PH00 bit screwdriver bit
      Ask FixBot
    10. Ivation IVWPDC20Y Flash Bulb Replacement: step 10, image 1 of 1
      • Gently lift the corner of the motherboard out
      • Everything should come out as one component free of the casing
      Ask FixBot
    11. Ivation IVWPDC20Y Flash Bulb Replacement: step 11, image 1 of 1
      • Remove the soldering on the three wires holding the flash bulb
      • The wires are different colors: red, white, and black
      Ask FixBot
Wendy Jones
225 Reputation
2 Guides authored
USF Tampa, Team 6-6, Eyestone Spring 2016 Member of USF Tampa, Team 6-6, Eyestone Spring 2016
USFT-EYESTONE-S16S6G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 535
