Up to 20% off select tools
Ivation IVWPDC20Y Display Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
75
All Time:
905
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the main rear-facing screen of the Ivation IVWPDC20Y camera.
    1. Ivation IVWPDC20Y Display Replacement, Display: step 1, image 1 of 1
      • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
      Ask FixBot
    2. Ivation IVWPDC20Y Display Replacement: step 2, image 1 of 1
      • Apply a plastic opening tool to each of the corners and gently remove the casing
      • The front casing is held down by adhesive and may require additional work to remove
      • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
      Ask FixBot
    3. Ivation IVWPDC20Y Display Replacement: step 3, image 1 of 1
      • Remove the five silver screws from the inner casing using the PH00 screwdriver bit.
      Ask FixBot
    4. Ivation IVWPDC20Y Display Replacement: step 4, image 1 of 1
      • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit.
      • These screws are very small and easy to strip so apply consistent pressure when removing them
      Ask FixBot
    5. Ivation IVWPDC20Y Display Replacement: step 5, image 1 of 1
      • Pry off back outer casing using the black spudger or the blue prying tools.
      Ask FixBot
    6. Ivation IVWPDC20Y Display Replacement: step 6, image 1 of 1
      • Carefully remove the screen from the silver casing using a prying tool or the black spudger.
      • There is adhesive in the center of the screen, be sure not to bend it when applying pressure.
      Ask FixBot
    7. Ivation IVWPDC20Y Display Replacement: step 7, image 1 of 1
      • Using the poker end of the spudger push gently on the black pegs holding the orange tape in place.
      • Screen and orange tape should slip out as a whole.
      Ask FixBot
Author
with
Alex
228 Reputation
2 Guides authored
USF Tampa, Team 6-6, Eyestone Spring 2016 Member of USF Tampa, Team 6-6, Eyestone Spring 2016
USFT-EYESTONE-S16S6G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 75
All Time: 905
