Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓How to check what trouble code a check engine light means on a first generation Isuzu Trooper (1981–1991).
To access trouble codes, a test lead (white wire) and ground lead (black wire) are branched from the wiring harness under the center console near the ECM.
With the ignition "ON" connect these two leads together.
The "Check Engine" light will begin to flash code 12. Code 12 consists of one flash, a short pause, then two flashes. After a longer pause, code 12 will repeat two more times.
CODE 12: Indicates that on-board diagnostics are functioning when diagnostic leads are connected and ignition is "ON" (engine not running). Code not stored in memory.
CODE 13: Oxygen sensor defective or open circuit.
CODE 14: Shorted coolant sensor circuit.
CODE 15: Open coolant sensor circuit.
CODE 21: Both idle and wide open throttle ON simultaneously in throttle valve switch.
CODE 22: Open or shorted starter signal circuit.
CODE 23: Shorted power transistor output terminal.
CODE 25: Open or shorted circuit for pressure regulator VSV.
CODE 26: Open or shorted circuit for canister VSV.
CODE 27: Open in ECM driver transistor for canister VSV.
CODE 32: EGR gas temperature sensor malfunction.
CODE 33: Open or shorted circuit in fuel injector harness, dropping resistor or inside ECM.
CODE 34: EGR gas temperature sensor or wiring faulty.
CODE 35: Ignition power transistor harness open circuit.
CODE 41: Crank angle sensor open circuit or faulty signal.
CODE 43: Throttle valve switch idle contact continuously ON.
CODE 44: Lean signal from oxygen sensor.
CODE 45: Rich signal from oxygen sensor.
CODE 51: Abnormal ROM in ECM micro computer.
CODE 52: Abnormal RAM in ECM micro computer.
CODE 53: Open in ECM driver transistor for pressure regulator VSV.
CODE 54: Defective ignition power transistor or grounding system.
CODE 61: Shorted or broken air flow sensor hot wire.
CODE 62: Broken air flow sensor cold wire.
CODE 63: Open or shorted wiring or defective vehicle speed sensor.
CODE 64: Open in ECM driver transistor for fuel injectors.
CODE 65: Wide open throttle contact in throttle valve switch continually ON.
