Ion Air Pro Body Cover Replacement
    1. Ion Air Pro Body Cover Replacement, Body Cover: step 1, image 1 of 1
      • Unscrew all six screws.
      • Make sure you put the screws in a good spot where you won't lose them because they are small.
      Ask FixBot
    2. Ion Air Pro Body Cover Replacement: step 2, image 1 of 1
      • After you're done with unscrewing, take off the blue lid shown here.
      Ask FixBot
    3. Ion Air Pro Body Cover Replacement: step 3, image 1 of 1
      • On the other side of the device, lift this black piece of cover that is underneath the cap, on the bottom side of the Ion Air Pro.
      Ask FixBot
    4. Ion Air Pro Body Cover Replacement: step 4, image 1 of 1
      • After removing the black lid, unscrew all eight screws here.
      • Again, make sure you keep track of your screws and don't lose them.
      Ask FixBot
    5. Ion Air Pro Body Cover Replacement: step 5, image 1 of 1
      • Remove two more screws, one on each side, inside this socket.
      Ask FixBot
    6. Ion Air Pro Body Cover Replacement: step 6, image 1 of 1
      • Next, unscrew the two screws located here.
      Ask FixBot
    7. Ion Air Pro Body Cover Replacement: step 7, image 1 of 1
      • Detach the bottom black piece off from the bottom side but do not disconnect it from the wires.
      • Everything inside is still connected with all the wires, so be careful not to pull too hard or else everything inside could fall out or get broken.
      Ask FixBot
    8. Ion Air Pro Body Cover Replacement: step 8, image 1 of 1
      • Finally, you can remove the body cover off and replace it with a new one if you have to.
      Ask FixBot
2 other people completed this guide.
Christopher Brandl
673 Reputation
5 Guides authored
UW Stout, Team S6-G2, Ogden Fall 2018 Member of UW Stout, Team S6-G2, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G2
4 Members
60 Guides authored
5 Guide Comments
Hey Chris where can I buy a replacement body cover?
The thread of the screw socket on my ion air pro WiFi has worn out and it can no longer be screwed onto any mounts.
Sam s - Reply Share
I LOST THE LOSTTHE REAR COVER WHILE HUNTING. iS THERE A REPLACEMENT I CAN GET
mcbee1010 - Reply Share
i lost the rear cover cap while hunting. can i purchase a new one
Can you show a photo of the other side (compared to step 8) showing the mounting thread please?
Andrew Mawby - Reply Share
Help: How to replace the battery, mine won't charge?
Kevin Harmon - Reply Share
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 36
All Time: 1,183
