Iomega Z100S2 Case Replacement
    1. Iomega Z100S2 Case Replacement, Case: step 1, image 1 of 2 Iomega Z100S2 Case Replacement, Case: step 1, image 2 of 2
      • Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
      Ask FixBot
    2. Iomega Z100S2 Case Replacement: step 2, image 1 of 1
      • Move down the same side and push in the plastic tab.
      Ask FixBot
    3. Iomega Z100S2 Case Replacement: step 3, image 1 of 1
      • Move to the front right side and once again push in the plastic tab.
      • There is not a fourth tab to push in after this one.
      Ask FixBot
    4. Iomega Z100S2 Case Replacement: step 4, image 1 of 2 Iomega Z100S2 Case Replacement: step 4, image 2 of 2
      • Grab the cover by the front side and pull upwards.
      • You might encounter some resistance. Pull firmly, but don't yank it.
      Ask FixBot
    5. Iomega Z100S2 Case Replacement: step 5, image 1 of 2 Iomega Z100S2 Case Replacement: step 5, image 2 of 2
      • Tilt the front case down until the pegs detach from the bottom of the case.
      • Lift up and outward.
      • The motherboard will be loose at this point.
      Ask FixBot
5 other people completed this guide.
Chris Rudolph
82 Reputation
1 Guide authored
Cal Poly, Team 7-53, Amido Fall 2010 Member of Cal Poly, Team 7-53, Amido Fall 2010
CPSU-AMIDO-F10S7G53
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 29
All Time: 4,690
