High power LED Mini flashlight, that stopped working after accidentally ending up in the washing machine. Stopped illuminating. Dried out, but did not respond properly to the ON / OFF button.
After performing various tests, a fault was seen in the button, a jumper on the 2 terminals of the button makes the LED board light up correctly: the problem is located in the 2 internal contacts of the button.
I tried without success, just to rule out that possibility, re-soldering the 2 connections of the button, but there was no improvement.
Therefore, the 2nd repair option, (since I don't have a suitable replacement button) is to apply "ELECTRONIC CLEANER" contact cleaner copiously while simultaneously sliding the button from one side to the other to try to clean the interior contact.
Subsequently, canned air was applied (Air canister on the right for cleaning keyboards) by means of which the inside of the button and the PCB were dried.
Once the PCB and the switch were dry, it was repeatedly tested, responding perfectly, so the flashlight was reassembled.
BE CAREFUL WITH THE BATTERY the truth is, it gave me a scare, during assembly; it became very hot in a few seconds because one of its terminals was short-circuited with the aluminum sheet of the LED, so to protect the terminals I chose to place protective insulating tape (Orange) covering the 2 terminals.
In order not to apply force in the re-assembly. A piece of black rubber was cut from the LED plate. (blue arrow)
Special thanks to these translators:
100%
Juan Garcia is helping us fix the world! Want to contribute?
Start translating ›
