Up to 20% off select tools
Interlink VP4550 Laser Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
38
All Time:
712
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Interlink VP4550 Laser Replacement, Case: step 1, image 1 of 3 Interlink VP4550 Laser Replacement, Case: step 1, image 2 of 3 Interlink VP4550 Laser Replacement, Case: step 1, image 3 of 3
      • Turn the phone over to where the battery compartment resides.
      • Remove the battery compartment door by pushing down on the door with your thumbs and sliding the door off of the bottom of the device.
      • Remove battery.
      Ask FixBot
    2. Interlink VP4550 Laser Replacement: step 2, image 1 of 3 Interlink VP4550 Laser Replacement: step 2, image 2 of 3 Interlink VP4550 Laser Replacement: step 2, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the screw in the middle of the battery compartment.
      • Pry open the case body with the plastic opening tool. Start at the bottom of the device and work toward the top. You will hear a "click" sound as the sides open.
      Ask FixBot
    3. Interlink VP4550 Laser Replacement: step 3, image 1 of 2 Interlink VP4550 Laser Replacement: step 3, image 2 of 2
      • There is a wire connector linking the front and the back of the device.
      • Carefully pull the wire connectors out of the white connector gauge to completely separate the front and back pieces.
      Ask FixBot
    4. Interlink VP4550 Laser Replacement: step 4, image 1 of 2 Interlink VP4550 Laser Replacement: step 4, image 2 of 2
      • The power button may fall off when you separate the front and back of the device. This can simply be placed back when reassembling.
      • Find the lever on the right side of the back half of the device.
      • Insert the tip of the lever into the square indent on the underside of the button.
      Ask FixBot
    1. Interlink VP4550 Laser Replacement, Circuit Board: step 5, image 1 of 1
      • Avoid picking up the front of the device as you work so that loose parts will not shift.
      • Use a Phillips #0 head screwdriver to remove two screws; one on either side of the circuit board.
      Ask FixBot
    2. Interlink VP4550 Laser Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Slide the circuit board down from the tab located underneath the top of the back half
      • The laser is attached to the circuit board and will slide out of its own housing as you slide out the circuit board.
      • Use tweezers to gently remove it if it doesn't come out.
      Ask FixBot
    1. Interlink VP4550 Laser Replacement, Laser: step 7, image 1 of 1
      • Use desoldering braid to remove the red and black wires attached to both the circuit board and the laser bulb.
      • When you are ready to attach the new laser bulb, use a soldering iron to solder the new bulb's wires to the circuit board.
      Ask FixBot
Finish Line
Author
with
Alayna Bruney
1 Reputation
1 Guide authored
Ohio State, Team 1-1, Buehl Spring 2014 Member of Ohio State, Team 1-1, Buehl Spring 2014
OSU-BUEHL-S14S1G1
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 38
All Time: 712
