Up to 20% off select tools
Interlink VP4550 Case Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
31
All Time:
752
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
Phone cases protect your phone's inner workings and screen from damage. In the event the case itself gets damaged, this guide will walk you through how to properly replace it. A Phillips #0 Screwdriver and a plastic opening tool will be needed to complete this. This repair will solve any problems that have to do with screen damage, and allows the user to put on an entirely brand new screen. This should take around 10 minutes to complete
    1. Interlink VP4550 Case Replacement, Case: step 1, image 1 of 3 Interlink VP4550 Case Replacement, Case: step 1, image 2 of 3 Interlink VP4550 Case Replacement, Case: step 1, image 3 of 3
      • Turn the phone over to where the battery compartment resides.
      • Remove the battery compartment door by pushing down on the door with your thumbs and sliding the door off of the bottom of the device.
      • Remove battery.
      Ask FixBot
    2. Interlink VP4550 Case Replacement: step 2, image 1 of 3 Interlink VP4550 Case Replacement: step 2, image 2 of 3 Interlink VP4550 Case Replacement: step 2, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the screw in the middle of the battery compartment.
      • Pry open the case body with the plastic opening tool. Start at the bottom of the device and work toward the top. You will hear a "click" sound as the sides open.
      Ask FixBot
    3. Interlink VP4550 Case Replacement: step 3, image 1 of 2 Interlink VP4550 Case Replacement: step 3, image 2 of 2
      • There is a wire connector linking the front and the back of the device.
      • Carefully pull the wire connectors out of the white connector gauge to completely separate the front and back pieces.
      Ask FixBot
    4. Interlink VP4550 Case Replacement: step 4, image 1 of 2 Interlink VP4550 Case Replacement: step 4, image 2 of 2
      • The power button may fall off when you separate the front and back of the device. This can simply be placed back when reassembling.
      • Find the lever on the right side of the back half of the device.
      • Insert the tip of the lever into the square indent on the underside of the button.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. It's possible to either use a new case for your phone, or put the old one back on.
Author
with
Rachel
1 Reputation
1 Guide authored
Ohio State, Team 1-1, Buehl Spring 2014 Member of Ohio State, Team 1-1, Buehl Spring 2014
OSU-BUEHL-S14S1G1
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 752
