Up to 20% off select tools
Intel NUC5i7RYH Disassembly
Views: 67K
View statistics:
Past 24 Hours:
33
Past 7 Days:
154
Past 30 Days:
598
All Time:
66,907
Comments: 24
9 comments on steps, 15 guide comments.
Go to guide comments
Completed: 21
21 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will provide information on how to disassemble an Intel NUC5i7RYH or similar.
    1. Intel NUC5i7RYH Disassembly, Lower Lid: step 1, image 1 of 2 Intel NUC5i7RYH Disassembly, Lower Lid: step 1, image 2 of 2
      • Place the NUC upside down and start by using a Phillips head screw driver to remove the lower screws on the lower case door.
      • These screws are held in with retainers, so they won't fall out when you flip the lid.
      Ask FixBot
    2. Intel NUC5i7RYH Disassembly, Lid and HDD Bracket: step 2, image 1 of 3 Intel NUC5i7RYH Disassembly, Lid and HDD Bracket: step 2, image 2 of 3 Intel NUC5i7RYH Disassembly, Lid and HDD Bracket: step 2, image 3 of 3
      • Lift the door, and keep an eye on the cables that connect to the NUC's motherboard. These cables are the power and data cables for the 2.5" hard drive bay.
      • Carefully unplug the cables from the motherboard, and set the bracket aside.
      • In the last photo, the slot for a blade SSD is marked. This is where you would install the blade SSD, and use a screw to hold it in place.
      Ask FixBot
    3. Intel NUC5i7RYH Disassembly, HDD Bracket Disassembly: step 3, image 1 of 3 Intel NUC5i7RYH Disassembly, HDD Bracket Disassembly: step 3, image 2 of 3 Intel NUC5i7RYH Disassembly, HDD Bracket Disassembly: step 3, image 3 of 3
      • Remove the 4 silver screws that hold the hard drive in the bracket. The metal shield with thermal pad in the red box will come off: this comes in handy if you have a blade SSD installed, as it insulates it from the metal.
      • Carefully slide the 2.5" HDD or SSD out of its case.
      Ask FixBot
    4. Intel NUC5i7RYH Disassembly, RAM Removal: step 4, image 1 of 3 Intel NUC5i7RYH Disassembly, RAM Removal: step 4, image 2 of 3 Intel NUC5i7RYH Disassembly, RAM Removal: step 4, image 3 of 3
      • Removal of RAM on these units is just like on a standard laptop: slightly bend each arm on each side of the chip, and allow it to pop up before sliding it out of the socket.
      • If using two sticks of RAM, repeat this process for the lower stick underneath.
      Ask FixBot
    5. Intel NUC5i7RYH Disassembly, Motherboard Removal: step 5, image 1 of 3 Intel NUC5i7RYH Disassembly, Motherboard Removal: step 5, image 2 of 3 Intel NUC5i7RYH Disassembly, Motherboard Removal: step 5, image 3 of 3
      • The motherboard is held in with two black Phillips head screws, located on the left hand side.
      • Be sure to unplug the antenna cables from the wireless card before removing the motherboard.
      • Grasp the ethernet port, and lift the board out of the case.
      Ask FixBot
    6. Intel NUC5i7RYH Disassembly, Motherboard Removal, continued.: step 6, image 1 of 3 Intel NUC5i7RYH Disassembly, Motherboard Removal, continued.: step 6, image 2 of 3 Intel NUC5i7RYH Disassembly, Motherboard Removal, continued.: step 6, image 3 of 3
      • The motherboard should lift right out of the case.
      • To remove the fan, unscrew the two Phillips head screws holding it in. It can then be unplugged from the motherboard.
      Ask FixBot
    7. Intel NUC5i7RYH Disassembly, Finish!: step 7, image 1 of 1
      • This unit is relatively easy to disassemble and reassemble. Good luck!
      Ask FixBot
21 other people completed this guide.
Author
with
Jasen Friedle
3,978 Reputation
3 Guides authored
15 Guide Comments
Clear description, I used it for NUC7i7RYH, where my cpu was often 100 degrees.
I followed your instruction and cleaned the ventilator and removed dust in the ventilation channels.
Problem fixed, temp is now between 50 and 70 degrees.
rob - Reply Share
Congrats! Thanks for letting me know, and I’m glad to hear your machine is running cooler!
Jasen Friedle - Reply Share
Hello, I need an audio jack (port) fro this nuc, can’t find it anywhere, any suggestions?
model 5i5ryh
dave - Reply Share
hello. I need a replacement audio jack (port) for this nuc, model 5i5ryh, can’t find it anywhere, any suggestions?
dave - Reply Share
You can try looking on eBay for replacement audio jacks. From what I’m seeing, you could potentially use a universal one and solder a few jumper wires to their corresponding pins and make something work.
Past 24 Hours: 33
Past 7 Days: 154
Past 30 Days: 598
All Time: 66,907
