Up to 20% off select tools
Integrated Headset Replacement
Views: 2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
38
Past 30 Days:
223
All Time:
2,047
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If you need to fix the play on a bike's rocking bars or replace the integrated headset on your bicycle, follow this guide. The process requires some disassembly but in the end you will have the correct adjustment on your headset. Alternatively, you may want to replace the headset entirely and make adjustments as necessary.
    1. Integrated Headset Replacement, Integrated Headset: step 1, image 1 of 3 Integrated Headset Replacement, Integrated Headset: step 1, image 2 of 3 Integrated Headset Replacement, Integrated Headset: step 1, image 3 of 3
      • Use a 6 mm Allen wrench to loosen the pinch bolts on each side of the stem.
      • Make sure to alternate between each side.
      Ask FixBot
    2. Integrated Headset Replacement: step 2, image 1 of 3 Integrated Headset Replacement: step 2, image 2 of 3 Integrated Headset Replacement: step 2, image 3 of 3
      • After loosening the bolts, the stem will be free to rotate.
      • Loosen and remove the top cap compression bolt.
      Ask FixBot
    3. Integrated Headset Replacement: step 3, image 1 of 3 Integrated Headset Replacement: step 3, image 2 of 3 Integrated Headset Replacement: step 3, image 3 of 3
      • Lift the bars and stem to remove them from the fork.
      • Turn the bars side to side while you pull up. This should help you remove a tight stem.
      Ask FixBot
    4. Integrated Headset Replacement: step 4, image 1 of 3 Integrated Headset Replacement: step 4, image 2 of 3 Integrated Headset Replacement: step 4, image 3 of 3
      • Remove the fork and headset from the bottom of the frame.
      Ask FixBot
    5. Integrated Headset Replacement: step 5, image 1 of 3 Integrated Headset Replacement: step 5, image 2 of 3 Integrated Headset Replacement: step 5, image 3 of 3
      • Remove the dust cap on top and replace the old bearings with the new headset if necessary.
      • Apply a thin coat of grease as needed on the frame’s head tube or steering head and fork.
      Ask FixBot
    6. Integrated Headset Replacement: step 6, image 1 of 3 Integrated Headset Replacement: step 6, image 2 of 3 Integrated Headset Replacement: step 6, image 3 of 3
      • Slide the fork back on the frame and place the compression ring on the upper headset bearing.
      Ask FixBot
    7. Integrated Headset Replacement: step 7, image 1 of 3 Integrated Headset Replacement: step 7, image 2 of 3 Integrated Headset Replacement: step 7, image 3 of 3
      • Slide the dust cover on and install the stem.
      • Check the amount of space between the top of the steerer tube and the top of your stem. Your steerer tube should lay just a few millimeters below, and allow for clamping and compression. If it doesn't, add a spacer on top of the dust cover and under the stem.
      Ask FixBot
    8. Integrated Headset Replacement: step 8, image 1 of 3 Integrated Headset Replacement: step 8, image 2 of 3 Integrated Headset Replacement: step 8, image 3 of 3
      • Reinstall the compression bolt and tighten it down, while at the same time keeping the bars in alignment.
      • Tighten the compression bolt until the thread becomes hard.
      • Use the socket wrench to turn the bolt half turn more and check for play by rocking the bars forward and backwards while pinching the frame with your knees.
      Ask FixBot
    9. Integrated Headset Replacement: step 9, image 1 of 3 Integrated Headset Replacement: step 9, image 2 of 3 Integrated Headset Replacement: step 9, image 3 of 3
      • Check for play and make sure the bars turn smoothly.
      • You don’t want to over tighten the compression bolt as this will result in improper steering.
      • Secure the pinching bolts on each side of the stem, alternating between each side as you go.
      Ask FixBot
The final product should end up with aligned and firm bars. There should be no forward or backwards play and everything should turn smoothly.
Author
with
Carlos
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 38
Past 30 Days: 223
All Time: 2,047
