Instax Mini 90 Battery Contact Replacement
Views: 5.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
117
All Time:
5,752
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This should be a fairly easy fix, since the only tool you need is a Phillips #000 screwdriver. There are no safety risks in this process, as long as you keep the camera turned off. The battery contact could have been damaged when the camera was dropped, or if the camera was not kept in a cool, clean, indoor environment. To prevent further damage to battery contact, only use the proper batteries from Fujifilm, and take caution to prevent battery leaks. Remove battery when the camera is not being used for long periods of time.
Parts
Tools
    1. Instax Mini 90 Battery Contact Replacement, Battery: step 1, image 1 of 2 Instax Mini 90 Battery Contact Replacement, Battery: step 1, image 2 of 2
      • The battery compartment can be found on the backside of the camera. Pinpoint this compartment and focus on the right edge of the compartment gate to find the opening latch.
      Ask FixBot
    2. Instax Mini 90 Battery Contact Replacement: step 2, image 1 of 2 Instax Mini 90 Battery Contact Replacement: step 2, image 2 of 2
      • Pinch the latch in towards the battery compartment gate. This will release the gate and allow it to open.
      • Completely open the gate and remove from camera. Take out the battery and replace the gate.
      Ask FixBot
    1. Instax Mini 90 Battery Contact Replacement, Battery Contact: step 3, image 1 of 3 Instax Mini 90 Battery Contact Replacement, Battery Contact: step 3, image 2 of 3 Instax Mini 90 Battery Contact Replacement, Battery Contact: step 3, image 3 of 3
      • Turn camera around to its backside.
      • Open up the back side of the camera by pushing up on the slide button. This button is located on the middle left side of the camera.
      Ask FixBot
    2. Instax Mini 90 Battery Contact Replacement: step 4, image 1 of 1
      • Use the Phillips #000 Screwdriver to remove the five 3.5 mm screws located in the backside door of the camera.
      Ask FixBot
    3. Instax Mini 90 Battery Contact Replacement: step 5, image 1 of 3 Instax Mini 90 Battery Contact Replacement: step 5, image 2 of 3 Instax Mini 90 Battery Contact Replacement: step 5, image 3 of 3
      • Remove the black plastic piece on top, then remove the thin, metal piece. This metal piece is the battery contact.
      • Replace the battery contact with the new one.
      Ask FixBot
2 other people completed this guide.
Elliott Tegan-Tawney
690 Reputation
5 Guides authored
USF Tampa, Team S2-G1, Nance Spring 2017 Member of USF Tampa, Team S2-G1, Nance Spring 2017
USFT-NANCE-S17S2G1
4 Members
72 Guides authored
1 Guide Comment
This guide only removes the battery tray. The contacts are visible in the last pic of the last step, still in place, under the red wire
John Doe - Reply Share
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 117
All Time: 5,752
