Instax Mini 90 Film Cartridge Replacement
Views: 25K
View statistics:
Past 24 Hours:
8
Past 7 Days:
44
Past 30 Days:
189
All Time:
24,755
Comments: 9
4 comments on steps, 5 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
A new Instax Mini 90 Film Cartridge is required for this process. The right size for this camera is 86mm x 54mm. This replacement is simple, but if you do not have the proper film cartridge, you will get an error notification from the camera. To get the most out of your film, keep it in a cool, dry place, and refrain from removing the cartridge while there are still exposures left on it.
    1. Instax Mini 90  Film Cartridge Replacement, Film Cartridge: step 1, image 1 of 1
      • Turn ON the camera, and flip it over so that the back cover is visible.
      Ask FixBot
    2. Instax Mini 90  Film Cartridge Replacement: step 2, image 1 of 3 Instax Mini 90  Film Cartridge Replacement: step 2, image 2 of 3 Instax Mini 90  Film Cartridge Replacement: step 2, image 3 of 3
      • Unlock the back cover. It should automatically spring open. If there is an old film cartridge loaded in the camera, remove it.
      Ask FixBot
    3. Instax Mini 90  Film Cartridge Replacement: step 3, image 1 of 3 Instax Mini 90  Film Cartridge Replacement: step 3, image 2 of 3 Instax Mini 90  Film Cartridge Replacement: step 3, image 3 of 3
      • Unwrap the new film cartridge, taking care to not touch the film inside. Only handle the film cartridge by its plastic shell.
      • Line up the small, yellow line on the cartridge with the corresponding yellow line inside the camera. The yellow line on the cartridge should be facing up, away from the camera.
      Ask FixBot
    4. Instax Mini 90  Film Cartridge Replacement: step 4, image 1 of 2 Instax Mini 90  Film Cartridge Replacement: step 4, image 2 of 2
      • Close the back cover. The film covering should eject automatically.
      Ask FixBot
Elliott Tegan-Tawney
690 Reputation
5 Guides authored
USF Tampa, Team S2-G1, Nance Spring 2017 Member of USF Tampa, Team S2-G1, Nance Spring 2017
USFT-NANCE-S17S2G1
4 Members
72 Guides authored
5 Guide Comments
Having an issue with the film pack not loading. Have tried resetting, removing battery etc. Any ideas?
Lawrence Cassel - Reply Share
Me too! Ive removed battery, replaced with fresh battery, nothing happens! Ive just used it once! Help!!
susan ahrent - Reply Share
I’m having the same problem and I’ve tried everything. Someone help! The film simply isn’t being recognized (no blinking E or anything like that).
ap5029 - Reply Share
I am not too sure how to fix that, but definitely try contacting Fujifilm, as they know much more about their products and do repairs as well! https://www.fujifilmusa.com/support/Serv...
Elliott Tegan-Tawney - Reply Share
I have a fujifilm instax mini evo hybrid black instant camera but it does not detect film. The message of putting a new cartridge keeps popping-up. Do you know what could be the cause?
Herman Saldana - Reply Share
Past 24 Hours: 8
Past 7 Days: 44
Past 30 Days: 189
All Time: 24,755
