Instant Pot IP-DUO80 V2 LED Display Replacement
    1. Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: step 1, image 1 of 3 Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: step 1, image 2 of 3 Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: step 1, image 3 of 3
      • Open the lid by turning it counter-clockwise and lifting up.
      • Remove the inner pot.
      Ask FixBot
    2. Instant Pot IP-DUO80 V2 LED Display Replacement: step 2, image 1 of 3 Instant Pot IP-DUO80 V2 LED Display Replacement: step 2, image 2 of 3 Instant Pot IP-DUO80 V2 LED Display Replacement: step 2, image 3 of 3
      • Turn the Instant Pot upside down.
      • Remove the single 12-mm screw by using the T-15 head screwdriver and turning it counter-clockwise.
      • Turn the plate counter-clockwise and lift it off the Instant Pot.
      Ask FixBot
    3. Instant Pot IP-DUO80 V2 LED Display Replacement: step 3, image 1 of 2 Instant Pot IP-DUO80 V2 LED Display Replacement: step 3, image 2 of 2
      • Remove the three 19-mm screws in the black plastic base's edge using the PH-1 head screwdriver and twisting counter-clockwise.
      Ask FixBot
    4. Instant Pot IP-DUO80 V2 LED Display Replacement: step 4, image 1 of 2 Instant Pot IP-DUO80 V2 LED Display Replacement: step 4, image 2 of 2
      • Pull the power cord out of its slot.
      • Pull up on the edge of the black plastic base to remove the base.
      Ask FixBot
    5. Instant Pot IP-DUO80 V2 LED Display Replacement: step 5, image 1 of 3 Instant Pot IP-DUO80 V2 LED Display Replacement: step 5, image 2 of 3 Instant Pot IP-DUO80 V2 LED Display Replacement: step 5, image 3 of 3
      • Disconnect the two green-striped yellow wires that are connected onto the bottom of the heating element. Use a PH-1 head screwdriver and turn counter-clockwise to remove the 10-mm screw holding them in place.
      • Be careful not to lose the small washer that comes with this screw.
      • Pull up on the cn101 connection to detach the LED display from the motherboard.
      Ask FixBot
    6. Instant Pot IP-DUO80 V2 LED Display Replacement: step 6, image 1 of 1
      • Lift the silver outer shell off of the top black ring.
      Ask FixBot
    7. Instant Pot IP-DUO80 V2 LED Display Replacement: step 7, image 1 of 3 Instant Pot IP-DUO80 V2 LED Display Replacement: step 7, image 2 of 3 Instant Pot IP-DUO80 V2 LED Display Replacement: step 7, image 3 of 3
      • Remove the two 10-mm screws connecting the LED display to the outer shell using a PH-1 head screwdriver and twisting counter clockwise.
      • Pull out the LED display by pulling on it gently.
      Ask FixBot
7 other people completed this guide.
Kayla Meacham
646 Reputation
5 Guides authored
Cal Poly, Team S18-G2, Livingston Winter 2018 Member of Cal Poly, Team S18-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G2
4 Members
60 Guides authored
2 Guide Comments
Where can I get the replacement for the display?
Starfish Doodle - Reply Share
Hola disculpa, donde puedo conseguir la pantalla led de mi instat pot DUO PLUS MULTI-COOKER 9in 1
Evaristo - Reply Share
Past 24 Hours: 6
Past 7 Days: 14
Past 30 Days: 83
All Time: 8,587
