Instant Pot IP-DUO80 V2 Float Valve Replacement
  1. Instant Pot IP-DUO80 V2 Float Valve Replacement, Float Valve: step 1, image 1 of 3 Instant Pot IP-DUO80 V2 Float Valve Replacement, Float Valve: step 1, image 2 of 3 Instant Pot IP-DUO80 V2 Float Valve Replacement, Float Valve: step 1, image 3 of 3
    • Remove the lid by twisting it counter-clockwise.
    Ask FixBot
  2. Instant Pot IP-DUO80 V2 Float Valve Replacement: step 2, image 1 of 1
    • Place the lid upside down on a stable surface.
    Ask FixBot
  3. Instant Pot IP-DUO80 V2 Float Valve Replacement: step 3, image 1 of 3 Instant Pot IP-DUO80 V2 Float Valve Replacement: step 3, image 2 of 3 Instant Pot IP-DUO80 V2 Float Valve Replacement: step 3, image 3 of 3
    • Remove the white rubber cover from the red float valve by pulling it off gently.
    • The red float valve will fall once the white cover is removed.
    Ask FixBot
2 other people completed this guide.
Kayla Meacham
646 Reputation
5 Guides authored
Cal Poly, Team S18-G2, Livingston Winter 2018 Member of Cal Poly, Team S18-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G2
4 Members
18 Guides authored
3 Guide Comments
On my model, the metal housing broke off, looks like it will need to be welded back together to the lid.
Harry Ethington - Reply Share
my float valve rubber is missing what can i do???how i can oder this how m gonna fix it kindly answer
ixbah aries - Reply Share
How do you remove the house that the pin goes into? Mine has corrosion on the pin and inside that housing.
Resist - Reply Share
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 53
All Time: 6,563
