Instant Pot 60 EPC Pressure Sensor Replacement
    1. Instant Pot 60 EPC Pressure Sensor Replacement, Pressure Sensor: step 1, image 1 of 3 Instant Pot 60 EPC Pressure Sensor Replacement, Pressure Sensor: step 1, image 2 of 3 Instant Pot 60 EPC Pressure Sensor Replacement, Pressure Sensor: step 1, image 3 of 3
      • Ensure the device is unplugged and cool before beginning.
      • Remove the lid and inner pot from the Instant Pot and turn the body upside down.
      • Remove the single Torx screw.
      Ask FixBot
    2. Instant Pot 60 EPC Pressure Sensor Replacement: step 2, image 1 of 2 Instant Pot 60 EPC Pressure Sensor Replacement: step 2, image 2 of 2
      • Turn the bottom face counterclockwise and remove it.
      Ask FixBot
    3. Instant Pot 60 EPC Pressure Sensor Replacement: step 3, image 1 of 3 Instant Pot 60 EPC Pressure Sensor Replacement: step 3, image 2 of 3 Instant Pot 60 EPC Pressure Sensor Replacement: step 3, image 3 of 3
      • In order to reach the pressure sensor you'll need to remove the secondary frame.
      • Remove the three Phillips screws securing the frame.
      • Lift the frame, twist and set next to the body. Take care not to damage any of the attached wiring.
      • Locate the sensor. It has been highlighted in the final image.
      Ask FixBot
    4. Instant Pot 60 EPC Pressure Sensor Replacement: step 4, image 1 of 2 Instant Pot 60 EPC Pressure Sensor Replacement: step 4, image 2 of 2
      • To remove the sensor, unscrew the main screw between the sensor and slide out.
      Ask FixBot
    5. Instant Pot 60 EPC Pressure Sensor Replacement: step 5, image 1 of 3 Instant Pot 60 EPC Pressure Sensor Replacement: step 5, image 2 of 3 Instant Pot 60 EPC Pressure Sensor Replacement: step 5, image 3 of 3
      • To remove the leads connecting the sensor to the motherboard you will need to unclip them.
      • In order to do so, slide the blue covering up to expose the small hole in the lead.
      • Place a SIM card punch into the hole to unsecure the leads and pull them up. If a SIM card punch is not avaliable then a paperclip or earring should suffice.
      Ask FixBot
    6. Instant Pot 60 EPC Pressure Sensor Replacement: step 6, image 1 of 2 Instant Pot 60 EPC Pressure Sensor Replacement: step 6, image 2 of 2
      • There will be a secondary lead that is black connecting the sensor the the motherboard.
      • In order to remove that lead just squeeze and pull up.
      Ask FixBot
    7. Instant Pot 60 EPC Pressure Sensor Replacement: step 7, image 1 of 1
      • Instant Pot does not provide a new sensor with the device, so it will have to be purchased from a secondary source.
      Ask FixBot
4 other people completed this guide.
2 Guide Comments
My pro plus comes with only one sensor. Where can I find it's replacement?
Dr. Khalid S - Reply Share
How does the pressure sensor work?
tjmurf - Reply Share
Past 24 Hours: 8
Past 7 Days: 22
Past 30 Days: 85
All Time: 1,223
