Instant Pot 60 EPC Circuit Board Replacement
  1. Instant Pot 60 EPC Circuit Board Replacement, Circuit Board: step 1, image 1 of 3 Instant Pot 60 EPC Circuit Board Replacement, Circuit Board: step 1, image 2 of 3 Instant Pot 60 EPC Circuit Board Replacement, Circuit Board: step 1, image 3 of 3
    • Ensure the device is unplugged and cool before beginning.
    • Remove the lid and inner pot from the Instant Pot and turn the body upside down.
    • Remove the single Torx screw.
    Ask FixBot
  2. Instant Pot 60 EPC Circuit Board Replacement: step 2, image 1 of 2 Instant Pot 60 EPC Circuit Board Replacement: step 2, image 2 of 2
    • Turn the bottom face counterclockwise and remove it.
    Ask FixBot
  3. Instant Pot 60 EPC Circuit Board Replacement: step 3, image 1 of 3 Instant Pot 60 EPC Circuit Board Replacement: step 3, image 2 of 3 Instant Pot 60 EPC Circuit Board Replacement: step 3, image 3 of 3
    • In order to reach the circuit board you'll need to remove the secondary frame surrounding it.
    • Remove the three Phillips screws securing the frame.
    • Lift the frame, twist and set next to the body. Take care not to damage any of the attached wiring.
    Ask FixBot
  4. Instant Pot 60 EPC Circuit Board Replacement: step 4, image 1 of 3 Instant Pot 60 EPC Circuit Board Replacement: step 4, image 2 of 3 Instant Pot 60 EPC Circuit Board Replacement: step 4, image 3 of 3
    • Depress the latch securing the red connector and disconnect it.
    • Repeat the previous bullet for the white and black connectors.
    • It can be helpful to gently rock them back and forth while pulling up.
    Ask FixBot
  5. Instant Pot 60 EPC Circuit Board Replacement: step 5, image 1 of 2 Instant Pot 60 EPC Circuit Board Replacement: step 5, image 2 of 2
    • Use a Phillips screwdriver to remove the two screws holding each of the two leads in place.
    Ask FixBot
  6. Instant Pot 60 EPC Circuit Board Replacement: step 6, image 1 of 2 Instant Pot 60 EPC Circuit Board Replacement: step 6, image 2 of 2
    • Gently walk the 8x1 pin connector out of its socket.
    • It may be helpful to also rock the plug side to side while pulling up.
    Ask FixBot
  7. Instant Pot 60 EPC Circuit Board Replacement: step 7, image 1 of 3 Instant Pot 60 EPC Circuit Board Replacement: step 7, image 2 of 3 Instant Pot 60 EPC Circuit Board Replacement: step 7, image 3 of 3
    • Slide the blue sheathing up to expose the small hole in the lead.
    • Place a SIM card punch into the hole to unsecure the leads and pull them up. If a SIM card punch is not available, then a paperclip or earring should suffice.
    • Repeat for the other two leads.
    Ask FixBot
  8. Instant Pot 60 EPC Circuit Board Replacement: step 8, image 1 of 2 Instant Pot 60 EPC Circuit Board Replacement: step 8, image 2 of 2
    • Pull the board up slightly to unclip it from its stand and lift from the body to remove the circuit board.
    Ask FixBot
  9. Instant Pot 60 EPC Circuit Board Replacement: step 9, image 1 of 1
    • Instant Pot does not provide a new sensor with the device, so it will have to be purchased from a secondary source.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 92
All Time: 1,411
