Up to 20% off select tools
Installing a Petsafe Removable Dog Panel
Views: 2.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
114
All Time:
2,244
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The Petsafe Dog Panel is a removable dog door that can be installed into the frame of your sliding glass door. Before continuing to the guide, make sure the Petsafe Dog Panel contains all the provided materials and that it is not damaged in any way. Please make sure to pay attention to the warnings before screwing into the panel or your door frame through out the installation process.
    1. Installing a Petsafe Removable Dog Panel, Petsafe Dog Panel: step 1, image 1 of 1
      • Make sure you have all the tools necessary.
      Ask FixBot
    2. Installing a Petsafe Removable Dog Panel: step 2, image 1 of 1
      • Receive your PetSafe dog door in the mail.
      Ask FixBot
    3. Installing a Petsafe Removable Dog Panel: step 3, image 1 of 2 Installing a Petsafe Removable Dog Panel: step 3, image 2 of 2
      • Measure the height of the sliding glass door frame.
      Ask FixBot
    4. Installing a Petsafe Removable Dog Panel: step 4, image 1 of 3 Installing a Petsafe Removable Dog Panel: step 4, image 2 of 3 Installing a Petsafe Removable Dog Panel: step 4, image 3 of 3
      • Remove your lock latch from the sliding door frame.
      • Lock latches may vary
      Ask FixBot
    5. Installing a Petsafe Removable Dog Panel: step 5, image 1 of 2 Installing a Petsafe Removable Dog Panel: step 5, image 2 of 2
      • Slide the top of your dog panel into the top track of the sliding glass door.
      • Place the bottom portion of the dog panel into the bottom track of the sliding glass door.
      Ask FixBot
    6. Installing a Petsafe Removable Dog Panel: step 6, image 1 of 2 Installing a Petsafe Removable Dog Panel: step 6, image 2 of 2
      • Measure 12” from the top, down the side of your sliding glass door frame and mark it.
      • Mark 1” above the pet flap onto the edge of your sliding glass door.
      Ask FixBot
    7. Installing a Petsafe Removable Dog Panel: step 7, image 1 of 3 Installing a Petsafe Removable Dog Panel: step 7, image 2 of 3 Installing a Petsafe Removable Dog Panel: step 7, image 3 of 3
      • With a 9/64ths drill bit, drill clearance holes into the marks made on the sliding glass door frame
      • DO NOT GO THROUGH THE DOG PANEL
      Ask FixBot
    8. Installing a Petsafe Removable Dog Panel: step 8, image 1 of 3 Installing a Petsafe Removable Dog Panel: step 8, image 2 of 3 Installing a Petsafe Removable Dog Panel: step 8, image 3 of 3
      • Fasten the panel to the interior side of the sliding glass frame with the provided ⅝” screws.
      • MAKE SURE YOU ARE DRILLING OUTSIDE OF THE RIBBED LINE ON THE DOG PANEL.
      • DO NOT OVERTIGHTEN.
      Ask FixBot
    9. Installing a Petsafe Removable Dog Panel: step 9, image 1 of 2 Installing a Petsafe Removable Dog Panel: step 9, image 2 of 2
      • Tighten the screws with a screwdriver.
      Ask FixBot
    10. Installing a Petsafe Removable Dog Panel: step 10, image 1 of 3 Installing a Petsafe Removable Dog Panel: step 10, image 2 of 3 Installing a Petsafe Removable Dog Panel: step 10, image 3 of 3
      • Repeat steps 8 and 9 to secure the dog panel into place. Follow these steps when drilling into the clearance hole marked at the top of the frame.
      Ask FixBot
    11. Installing a Petsafe Removable Dog Panel: step 11, image 1 of 1
      • Slide your sliding door flush against the dog door.
      Ask FixBot
Author
with
Joshua Novello
196 Reputation
1 Guide authored
UC Davis, Team S1-G1, Bender Fall 2018 Member of UC Davis, Team S1-G1, Bender Fall 2018
UCD-BENDER-F18S1G1
3 Members
12 Guides authored
2 Guide Comments
My dog won’t push hard enough for the magnet to open. Is there a way to temporarily remove the magnet on either the frame or the flap?
LisaD - Reply Share
LisaD put a piece of masking tape over the magnet or a couple of layers of tape to make it easier to open maybe?
Robert Merry - Reply Share
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 114
All Time: 2,244
