Up to 20% off select tools
Installing Mercedes W166 RAV Tool Box
Views: 5.9K
View statistics:
Past 24 Hours:
Past 7 Days:
21
Past 30 Days:
110
All Time:
5,904
Comments: 1
1 comment on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 3 hours
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Community-Contributed Guide
    1. Installing Mercedes W166 RAV Tool Box, RAV Tool Box: step 1, image 1 of 2 Installing Mercedes W166 RAV Tool Box, RAV Tool Box: step 1, image 2 of 2
      • 1. Vehicle Preparation
      • Remove all loose items from the cargo area. Remove the cargo floor, spare wheel and tool tray.
      • Remove rear seats as in WIS instructions (Save seat mounting hardware)
      Ask FixBot
    2. Installing Mercedes W166 RAV Tool Box: step 2, image 1 of 3 Installing Mercedes W166 RAV Tool Box: step 2, image 2 of 3 Installing Mercedes W166 RAV Tool Box: step 2, image 3 of 3
      • Remove bolt from rear deck sill plate
      • Unclip rear deck sill plate and remove.
      Ask FixBot
    3. Installing Mercedes W166 RAV Tool Box: step 3, image 1 of 1
      • Remove plastic covers
      • Remove Felt liner
      Ask FixBot
    4. Installing Mercedes W166 RAV Tool Box: step 4, image 1 of 3 Installing Mercedes W166 RAV Tool Box: step 4, image 2 of 3 Installing Mercedes W166 RAV Tool Box: step 4, image 3 of 3
      • Remove side consoles and center support (T30 10 Bolts)
      Ask FixBot
    5. Installing Mercedes W166 RAV Tool Box: step 5, image 1 of 3 Installing Mercedes W166 RAV Tool Box: step 5, image 2 of 3 Installing Mercedes W166 RAV Tool Box: step 5, image 3 of 3
      • Install and bolt down center support bracket (2 Bolts M10 x 1.5 x35mm 6mm Allen cap, 10mm flat washers)
      • Pay attention to the pin to align properly
      • NOTE: To service TPMS control module remove drawers ad service through access door in bottom plate.
      Ask FixBot
    6. Installing Mercedes W166 RAV Tool Box: step 6, image 1 of 3 Installing Mercedes W166 RAV Tool Box: step 6, image 2 of 3 Installing Mercedes W166 RAV Tool Box: step 6, image 3 of 3
      • 2. Installation of Front Box
      • Place box inside vehicle. It fits through the rear doors. This is a 2 person job.
      • Mount front legs on front consoles, tighten loosely (2 Bolts M10 x 1.5 x35mm 6mm Allen cap, 10mm flat washers). Pay attention not to break off the alignment pin, which will be inside the post after mounting.
      • DO NOT mount the box to the center bracket at this point
      Ask FixBot
    7. Installing Mercedes W166 RAV Tool Box: step 7, image 1 of 2 Installing Mercedes W166 RAV Tool Box: step 7, image 2 of 2
      • 3. Installation of the rear plate
      • Install 6 rear support brackets and tighten finger tight
      Ask FixBot
    8. Installing Mercedes W166 RAV Tool Box: step 8, image 1 of 3 Installing Mercedes W166 RAV Tool Box: step 8, image 2 of 3 Installing Mercedes W166 RAV Tool Box: step 8, image 3 of 3
      • Set plate on brackets and align, overlapping the base plate of the front box on the center support bracket.
      • Use punch tool to align holes and drop in 2 bolts M8 x 1.25 x 40mm in holes on each side and one bolt M8 x 1.25 x 30 in the center hole.
      Ask FixBot
    9. Installing Mercedes W166 RAV Tool Box: step 9, image 1 of 3 Installing Mercedes W166 RAV Tool Box: step 9, image 2 of 3 Installing Mercedes W166 RAV Tool Box: step 9, image 3 of 3
      • Secure plate to center support bracket with 2 bolts on the outside and on in the middle, align and finger tighten
      Ask FixBot
    10. Installing Mercedes W166 RAV Tool Box: step 10, image 1 of 2 Installing Mercedes W166 RAV Tool Box: step 10, image 2 of 2
      • Install 3 bolts securing base plate to vehicle frame
      • and 4th bolt securing the tool box rail to the base plate and vehicle frame.
      • Put bolt sizes in
      Ask FixBot
    11. Installing Mercedes W166 RAV Tool Box: step 11, image 1 of 2 Installing Mercedes W166 RAV Tool Box: step 11, image 2 of 2
      • Install and loosely tighten 3 M8 black oxide bolts on each side until L bracket touches the underside of the base plate
      Ask FixBot
    12. Installing Mercedes W166 RAV Tool Box: step 12, image 1 of 2 Installing Mercedes W166 RAV Tool Box: step 12, image 2 of 2
      • Fully tighten M8 (20 Nm)
      • Fully tighten M6 (8 Nm)
      Ask FixBot
    13. Installing Mercedes W166 RAV Tool Box: step 13, image 1 of 3 Installing Mercedes W166 RAV Tool Box: step 13, image 2 of 3 Installing Mercedes W166 RAV Tool Box: step 13, image 3 of 3
      • Fully tighten M10 bolts (35 Nm)
      Ask FixBot
    14. Installing Mercedes W166 RAV Tool Box: step 14, image 1 of 3 Installing Mercedes W166 RAV Tool Box: step 14, image 2 of 3 Installing Mercedes W166 RAV Tool Box: step 14, image 3 of 3
      • 4. Install box
      • Remove drawers and slide box on rail guides, align with bolt holes
      • Install 6 (M12) bolts and fully tighten to 66 Nm
      Ask FixBot
    15. Installing Mercedes W166 RAV Tool Box: step 15, image 1 of 3 Installing Mercedes W166 RAV Tool Box: step 15, image 2 of 3 Installing Mercedes W166 RAV Tool Box: step 15, image 3 of 3
      • Install drawers.
      • After drawer is installed move rail clip to locked position
      Ask FixBot
    16. Installing Mercedes W166 RAV Tool Box: step 16, image 1 of 1
      • Fasten seat belt with bolt to floor
      Ask FixBot
Finish Line
5 other people completed this guide.
Author
with
Stefan
302 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 110
All Time: 5,904
