Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive
    1. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive, Remove the lower case screws: step 1, image 1 of 1
      • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
      • Seven 3 mm Phillips screws.
      Ask FixBot
    2. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive, Lift the lower case away: step 2, image 1 of 1
      • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
      Ask FixBot
    1. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive, Battery: step 3, image 1 of 1
      • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
      • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
      Ask FixBot
    1. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive, Optical Drive: step 4, image 1 of 1
      • For precautionary purposes, we advise that you disconnect the subwoofer connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
      • Remove the soft padding that may be on top and gently pull the connector up out of its socket on the logic board.
      Ask FixBot
    2. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 5, image 1 of 1
      • It will be necessary to slide the small clear plastic cable retainer (boxed in red) glued to the logic board out of the way before disconnecting the camera cable. Be careful not to break any components off the board as you slide it away from the camera cable connector.
      • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
      • This socket is metal and can be easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
      Ask FixBot
    3. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 6, image 1 of 1
      • Use the flat end of a spudger to pry the optical drive connector straight up off the logic board.
      Ask FixBot
    4. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 7, image 1 of 1
      • Use the flat end of a spudger to pry the hard drive connector straight up off the logic board.
      Ask FixBot
    5. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 8, image 1 of 1
      • Remove the following screws securing the subwoofer to the upper case:
      • One 3.8 mm Phillips screw
      • One 5 mm Phillips screw
      Ask FixBot
    6. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 9, image 1 of 2 Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 9, image 2 of 2
      • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
      • Lift the subwoofer off the optical drive, and set it above the computer.
      Ask FixBot
    7. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 10, image 1 of 2 Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 10, image 2 of 2
      • Remove the two 10 mm Phillips screws securing the camera cable bracket to the upper case.
      • The leftmost screw may remain captive in the camera cable.
      • Lift the camera cable bracket out of the upper case.
      Ask FixBot
    8. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 11, image 1 of 2 Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 11, image 2 of 2
      • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
      • Lift the optical drive from its right edge and pull it out of the computer.
      Ask FixBot
    1. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive, Optical Drive: step 12, image 1 of 1
      • Remove the optical drive cable by pulling it straight away from the optical drive.
      • This connector is particularly deep, so be sure to pull away from the drive at the center of the connector.
      • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
      Ask FixBot
    2. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 13, image 1 of 1
      • Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
      Ask FixBot
    1. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive, Dual Hard Drive: step 14, image 1 of 2 Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive, Dual Hard Drive: step 14, image 2 of 2
      • Remove the plastic spacer from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
      Ask FixBot
    2. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 15, image 1 of 3 Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 15, image 2 of 3 Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 15, image 3 of 3
      • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
      • Gently place the hard drive into the enclosure's hard drive slot.
      • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
      Ask FixBot
    3. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 16, image 1 of 2 Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 16, image 2 of 2
      • Once the hard drive is snug, reinsert the plastic spacer while holding the hard drive against the bottom of the enclosure.
      Ask FixBot
    4. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 17, image 1 of 2 Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 17, image 2 of 2
      • Use two Phillips #1 screws to secure the drive to its enclosure.
      Ask FixBot
    5. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 18, image 1 of 1
      • Attach the optical drive bracket to the new enclosure with two Phillips #0 screws.
      • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
      Ask FixBot
    6. Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 19, image 1 of 3 Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 19, image 2 of 3 Installing MacBook Pro 13" Unibody Mid 2010 Dual Hard Drive: step 19, image 3 of 3
      • Don't ditch that drive! You can still use your optical drive externally with the help of our SATA Optical Drive USB Cable.
      • Align the cable's SATA connector with the drive's port and plug in securely.
      • Plug the USB connector into your laptop and your optical drive is ready for use.
      Ask FixBot
107 other people completed this guide.
iRobot
1 Reputation
632 Guides authored
5 Guide Comments
I bought a 1TB SSD/hybrid drive from Ifixit.com to upgrade the 256GB HDD that came with MBP 2010. Disk Utility could not see the new drive on the original HDD cable but saw the old one just fine. New replacement cable was not the correct size for the MBP 2010 but worked just fine in my other MBP 2012. Put the stock HDD back in with the original HDD cable, removed the optical drive and replaced with the 1TB dual drive per instructions without problems. I have read online that the SATA HDD cable in MBP 2009 and early 2010 was too slow to read modern high-speed SATA drives.
Only glitch I found is DVD/CDs will not mount in the optical drive using the external USB cable that came with the dual disk kit purchased here. Will eventually have to find time to try swapping the optical drive with my other laptop to test internally as well as the external cable. At this point I don't care, didn't use the optical, love the two working internal disk drives. Thanks guys!
Bob - Reply Share
I replaced Primary HDD with SSD and moved HDD to optical slot with caddy, and it seems works, but HDD in optical slot is incredibly slow now. Macbook 7.1. Sierra. SSD Savage 250Gb.
Roman Nicolaevich - Reply Share
Smoooooth, like butta. Thanks for another great guide and parts. My 2010 macbook pro now has an ssd running fast w sierra, and my conventional drive for lots of storage. About $200 for ssd and the parts, and my computer will be in good shape for a few more years!
Brian Eldridge - Reply Share
Merci beaucoup, c'est génial ! J'ai juste eu des difficultés avec le connecteur du caisson basse. Je l'ai enlevé et impossible de le remettre en place. C'est sans conséquence pour moi, j'utilise la sortie audio.
Bravo et encore merci !
Laskoni - Reply Share
anyone know where I can buy the cd reader
Greg Roux - Reply Share
Past 24 Hours: 6
Past 7 Days: 29
Past 30 Days: 119
All Time: 117,456
