Up to 20% off select tools
Installing Mac mini Mid 2010 Dual Drive
Views: 105K
View statistics:
Past 24 Hours:
13
Past 7 Days:
52
Past 30 Days:
249
All Time:
104,534
Comments: 115
100 comments on steps, 15 guide comments.
Go to guide comments
Completed: 83
83 people have marked this guide "completed." Will you be next?
Favorites: 70
70 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to trade your optical drive for a second hard drive or SSD.
    1. Installing Mac mini Mid 2010 Dual Drive, Bottom Cover: step 1, image 1 of 2 Installing Mac mini Mid 2010 Dual Drive, Bottom Cover: step 1, image 2 of 2
      • Place your thumbs in the depressions cut into the bottom cover.
      • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
      Ask FixBot
    2. Installing Mac mini Mid 2010 Dual Drive: step 2, image 1 of 1
      • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
      • Remove the bottom cover and set it aside.
      Ask FixBot
    1. Installing Mac mini Mid 2010 Dual Drive, Fan: step 3, image 1 of 1
      • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
      Ask FixBot
    2. Installing Mac mini Mid 2010 Dual Drive: step 4, image 1 of 1
      • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
      • If the fan doesn't separate from the standoff screw with a moderate amount of force, you can use a T6 Torx driver to simply remove this screw.
      Ask FixBot
    3. Installing Mac mini Mid 2010 Dual Drive: step 5, image 1 of 1
      • Lift the fan out of the mini for enough clearance to access its connector.
      • Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
      • Remove the fan.
      Ask FixBot
    1. Installing Mac mini Mid 2010 Dual Drive, Cowling: step 6, image 1 of 1
      • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
      Ask FixBot
    2. Installing Mac mini Mid 2010 Dual Drive: step 7, image 1 of 1
      • Lift the cowling from the end nearest the antenna plate.
      • Rotate the cowling away from the outer case and remove it from the mini.
      Ask FixBot
    1. Installing Mac mini Mid 2010 Dual Drive, Antenna Plate: step 8, image 1 of 1
      • Remove the following screws securing the antenna plate to the mini:
      • Two 6.6 mm T8 or T9 Torx screws
      • Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either will work)
      Ask FixBot
    2. Installing Mac mini Mid 2010 Dual Drive: step 9, image 1 of 2 Installing Mac mini Mid 2010 Dual Drive: step 9, image 2 of 2
      • Slightly lift the antenna plate from the end closest to the RAM.
      • Carefully pull the antenna plate straight away from the circular rim of the outer case.
      • Do not remove the antenna plate yet. It is still attached to the AirPort/ Bluetooth board.
      Ask FixBot
    3. Installing Mac mini Mid 2010 Dual Drive: step 10, image 1 of 1
      • Use the tip of a spudger to carefully pry the antenna connector up off the AirPort/Bluetooth board.
      Ask FixBot
    4. Installing Mac mini Mid 2010 Dual Drive: step 11, image 1 of 1
      • Remove the antenna plate from the mini.
      Ask FixBot
    1. Installing Mac mini Mid 2010 Dual Drive, Logic Board: step 12, image 1 of 1
      • Remove the following three screws:
      • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either will work)
      • One 16.2 mm T6 Torx screw
      • One 26 mm T6 Torx standoff
      Ask FixBot
    2. Installing Mac mini Mid 2010 Dual Drive: step 13, image 1 of 2 Installing Mac mini Mid 2010 Dual Drive: step 13, image 2 of 2
      • Carefully pull the wires for both hard drive thermal sensors upward to lift their connectors up and out of the sockets on the logic board.
      Ask FixBot
    3. Installing Mac mini Mid 2010 Dual Drive: step 14, image 1 of 2 Installing Mac mini Mid 2010 Dual Drive: step 14, image 2 of 2
      • Use the flat end of a spudger to pry both the hard drive and optical drive connectors up out of their sockets on the logic board.
      Ask FixBot
    4. Installing Mac mini Mid 2010 Dual Drive: step 15, image 1 of 1
      • To disconnect the optical drive thermal sensor, pinch its cables between your thumb and a spudger and pry the spudger upward to lift the connector up and out of its socket on the logic board.
      Ask FixBot
    5. Installing Mac mini Mid 2010 Dual Drive: step 16, image 1 of 1
      • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
      Ask FixBot
    6. Installing Mac mini Mid 2010 Dual Drive: step 17, image 1 of 3 Installing Mac mini Mid 2010 Dual Drive: step 17, image 2 of 3 Installing Mac mini Mid 2010 Dual Drive: step 17, image 3 of 3
      Tool used on this step:
      Mac mini Logic Board Removal Tool
      Buy
      • To remove the logic board, two cylindrical rods must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
      • Insert a Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the outer case below the logic board before proceeding.
      • If you don't have a Logic Board Removal Tool handy, you can use two tools having a maximum diameter of 2.5 mm instead. Just insert one into each of the highlighted holes.
      • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
      • Cease prying when the I/O board is visibly separated from the outer case. Remove the Mac mini Logic Board Removal tool.
      Ask FixBot
    7. Installing Mac mini Mid 2010 Dual Drive: step 18, image 1 of 1
      • Simultaneously push the two plastic clips on the far left and right sides of the I/O board toward the middle of the I/O board and pull the I/O board away from the outer case.
      Ask FixBot
    8. Installing Mac mini Mid 2010 Dual Drive: step 19, image 1 of 1
      Buy
      • Pull the I/O board/logic board assembly out of the outer case enough to access the power connector.
      • Use a pair of tweezers to disconnect the power cable from the logic board.
      • Pull the power cable connector toward the optical drive opening.
      Ask FixBot
    9. Installing Mac mini Mid 2010 Dual Drive: step 20, image 1 of 1
      • Carefully slide the logic board assembly out of the mini, minding any cables that may get caught.
      Ask FixBot
    1. Installing Mac mini Mid 2010 Dual Drive, Power Supply: step 21, image 1 of 1
      • Remove the 7.9 mm T6 Torx screw securing the power supply and optical drive to the outer case.
      Ask FixBot
    2. Installing Mac mini Mid 2010 Dual Drive: step 22, image 1 of 2 Installing Mac mini Mid 2010 Dual Drive: step 22, image 2 of 2
      • Pull the silver metal AC-In socket retainer away from the side of the outer case and remove it from the mini.
      Ask FixBot
    3. Installing Mac mini Mid 2010 Dual Drive: step 23, image 1 of 2 Installing Mac mini Mid 2010 Dual Drive: step 23, image 2 of 2
      • Rotate the AC-In connector 90 degrees counter-clockwise.
      Ask FixBot
    4. Installing Mac mini Mid 2010 Dual Drive: step 24, image 1 of 1
      • Slide the power supply out of the mini, minding any cables that may get caught.
      Ask FixBot
    1. Installing Mac mini Mid 2010 Dual Drive, Optical Drive: step 25, image 1 of 1
      • Remove the hard drive from the mini, minding any cables that may get caught.
      Ask FixBot
    2. Installing Mac mini Mid 2010 Dual Drive: step 26, image 1 of 1
      • Remove the 7.9 mm T6 Torx screw securing the optical drive to the outer case.
      Ask FixBot
    3. Installing Mac mini Mid 2010 Dual Drive: step 27, image 1 of 1
      • Slide the optical drive out of the outer case, minding any cables that may get caught.
      Ask FixBot
    1. Installing Mac mini Mid 2010 Dual Drive, Optical Drive: step 28, image 1 of 1
      • Carefully de-route the IR sensor cables from the channel in the optical drive bracket.
      Ask FixBot
    2. Installing Mac mini Mid 2010 Dual Drive: step 29, image 1 of 2 Installing Mac mini Mid 2010 Dual Drive: step 29, image 2 of 2
      • Remove the two 6.3 mm T6 Torx screws securing both sides of the optical drive bracket to the optical drive (four screws total).
      Ask FixBot
    3. Installing Mac mini Mid 2010 Dual Drive: step 30, image 1 of 1
      • Remove the optical drive bracket from the optical drive, minding any cables that may get caught.
      Ask FixBot
    4. Installing Mac mini Mid 2010 Dual Drive: step 31, image 1 of 1
      • Carefully peel the optical drive ribbon cable off the body of the optical drive.
      Ask FixBot
    5. Installing Mac mini Mid 2010 Dual Drive: step 32, image 1 of 1
      • Disconnect the optical drive cable by pulling its connector away from the body of the optical drive.
      Ask FixBot
    6. Installing Mac mini Mid 2010 Dual Drive: step 33, image 1 of 1
      • Peel off the strip of black tape covering the optical drive thermal sensor.
      Ask FixBot
    7. Installing Mac mini Mid 2010 Dual Drive: step 34, image 1 of 1
      • Carefully pry the optical drive thermal sensor off the adhesive securing it to the optical drive.
      • It may be necessary to use a strip of tape or rubber cement to attach the thermal sensor to your new optical drive.
      • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
      Ask FixBot
    1. Installing Mac mini Mid 2010 Dual Drive, Dual Hard Drive: step 35, image 1 of 2 Installing Mac mini Mid 2010 Dual Drive, Dual Hard Drive: step 35, image 2 of 2
      • Remove the plastic positioner from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
      Ask FixBot
    2. Installing Mac mini Mid 2010 Dual Drive: step 36, image 1 of 3 Installing Mac mini Mid 2010 Dual Drive: step 36, image 2 of 3 Installing Mac mini Mid 2010 Dual Drive: step 36, image 3 of 3
      • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
      • Gently place the hard drive into the enclosure's hard drive slot.
      • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
      Ask FixBot
    3. Installing Mac mini Mid 2010 Dual Drive: step 37, image 1 of 2 Installing Mac mini Mid 2010 Dual Drive: step 37, image 2 of 2
      • Once the hard drive is snug, reinsert the plastic positioner while holding the hard drive against the bottom of the enclosure.
      • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
      Ask FixBot
83 other people completed this guide.
Author
with
Brittany McCrigler
91,191 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
15 Guide Comments
I've run through this tutorial twice. First time I switched our the HDD for a 1tb, and the DVD drive for an SSD. The HDD works but the machine didn't find the SSD. I then swapped them - it now finds the SSD but not in the HDD which is now in what used to be the optical drive slot.
Do I need to buy a new cable for the optical drive? As it appears that's what it's not reading, or is there something I've missed?
Thanks
Josh G - Reply Share
You need to go to Disk Utility and format the SSD/Hard Drive.
- PS5iscool - - Reply Share
Just completed this in under an hour, thanks in part to reading the whole guide once over before and reading all the comments about the various different steps, so thanks also to the commenters!
Amazingly, system booted first time and it sees the 2nd HDD (SSD actually), now to try setting up a Fusion drive :-)
Simon Martin - Reply Share
I did it! With lots of help from my friends who work at an apple repair store... perhaps that is cheating?
I too am having trouble now with the disk utility recognizing the newly installed hard drive. Did I miss something? I followed the instructions perfectly. And my repair friends helped me with the "why won't this fit back together you tiny unibody you!"
Any suggestions for how to get the disk utility to recognize my drive I just worked so hard to put in there would be greatly appreciated!
kmvbconover - Reply Share
achtet auf die Bauhöhe der Festplatte! Man bekommt zwar eine 12,1 mm hohe Platte rein, aber es wird alles mehr als eng
dirkmutik - Reply Share
Past 24 Hours: 13
Past 7 Days: 52
Past 30 Days: 249
All Time: 104,534
