Up to 20% off select tools
Install macOS Printer Drivers
Views: 6.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
27
Past 30 Days:
181
All Time:
6,054
Comments: 2
2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Fix the problem "This update requires macOS 12.0 or earlier." Or install printer drivers on macOS. (Pilots, Drivers)
    1. Install macOS Printer Drivers, Install macOS Printer Drivers: step 1, image 1 of 2 Install macOS Printer Drivers, Install macOS Printer Drivers: step 1, image 2 of 2
      • Find the driver for your printer brand on the link below:
      • https://support.apple.com/kb/index?page=...
      • Download the driver for your printer, by clicking on the "Download" button.
      • If the message: "This connection is not private" appears, open the page with the private mode of your browser.
      Ask FixBot
    2. Install macOS Printer Drivers: step 2, image 1 of 2 Install macOS Printer Drivers: step 2, image 2 of 2
      • Open your .dmg file
      • Open your .pkg file
      • If this message appears: "This update requires macOS 12.0 or earlier." click Close and continue with the next step.
      • Otherwise, continue with step 7.
      Ask FixBot
    3. Install macOS Printer Drivers: step 3, image 1 of 3 Install macOS Printer Drivers: step 3, image 2 of 3 Install macOS Printer Drivers: step 3, image 3 of 3
      • Move your .pkg file to your desktop
      • Open Terminal
      • Enter: cd Desktop/ then press the Enter key
      Ask FixBot
    4. Install macOS Printer Drivers: step 4, image 1 of 3 Install macOS Printer Drivers: step 4, image 2 of 3 Install macOS Printer Drivers: step 4, image 3 of 3
      • Enter the following command: pkgutil --expand FileName.pkg FileName
      • Change FileName to the name of your file, in both places.
      • Then press the Enter key.
      • A folder with the file name appears on your desktop.
      • Open the folder.
      Ask FixBot
    5. Install macOS Printer Drivers: step 5, image 1 of 2 Install macOS Printer Drivers: step 5, image 2 of 2
      • Open the Distribution file with TextEdit
      • Then change the number after (system.compareVersions(system.version.ProductVersion, '12.0')" to that of your macOS version or later.
      • Save the file and close it.
      Ask FixBot
    6. Install macOS Printer Drivers: step 6, image 1 of 2 Install macOS Printer Drivers: step 6, image 2 of 2
      • Return to the Terminal
      • Enter the following command: pkgutil --flatten FileName FileName.pkg and press the Enter key.
      • Close theTerminal and open FileName.pkg on your desktop.
      Ask FixBot
    7. Install macOS Printer Drivers: step 7, image 1 of 1
      • Congratulations, you can proceed with the installation by following the steps one by one.
      Ask FixBot
Congratulations, you made it!
4 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Anthony Fassler
7,152 Reputation
4 Guides authored
2 Guide Comments
Merci pour cet excellent tutoriel, j'ai récupéré le fonctionnement de mon ancienne imprimante HP sur mon Mac !
Bravo !!!
Cédric Trocellier - Reply Share
Bonjours ,j'ai un ordinateur imac et je veux installer une imprimante canon, je dois telecharger un logiciel pour ça et je n'y arrive pas; pouvez vous m'aider svp; merci
Moh Cho - Reply Share
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 181
All Time: 6,054
